    Reputation: jfn3's Avatar
    100mm fork okay for my furio frame ?
    I bought a conversion headset for my frame (I dont like the headshok) and was wondering, Is a 100 mm fork okay (reba, recon or mantiou black) okay for my furio frame or will it void the warranty or make it handle like a wheelbarrow full of dog poop? thanks for any random thoughts! johnny five
    My 2004 F800 Furio came with a 100mm fork (Lefty) - if yours is a similar age it should be fine.
    Alaric.
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    Yep. 100mm is pretty common for hard tails.
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
    Mar 2005
    doesn't void the the warranty until you pass 500mm for fork axle-crown plus lower headset stack height. those forks should all be around 475 mm, plus say 15 mm or so for with the headset lower cup. You should be fine and depending on what headshok you have, fork length and the head angle will likely remain about the same.
