Results 1 to 7 of 7
    Mar 2012
    12 Scalpel 2x10 front mech HELP.. Is that what it should look like?
    Just don't seem right?!? The cable pulling off the the side like that.
    Mar 2012
    Any 2012 Scalpel 26 owners out there that could have a look.. 2x10 shimano.
    Dec 2010
    That is a dual pull front mech.. the gear cable can be routed from the top or the bottom depending on the cable run of your frame..
    Yes, its not very tidy looking but it should be just fine as it is.. although you may want to swap the routing into the adjacent hole for a cleaner line.. and possibly smoother shifting..
    The names have been changed to protect the innocent...
    Mar 2012
    Thanks. Still find it hard to believe there is not another derailleur that would fit better..
    If only I know someone with a 12 Scalpel I could have a look.
    Since no one can bother to have a look at theres
    btc
    btc is offline
    Mar 2006
    Hope this will help(@ 1:50), cable go straight to the left at pinch bolt.
    https://www.youtube.com/watch?v=uddXYWdhdIU
    btc
    btc is offline
    Mar 2006
    Mar 2012
    Job done!
    Attachment 989942
  1. SRAM X9 Direct mount 2X10 front mech issues
    By scarlet in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-18-2013, 01:58 PM
  2. xtr front mech for 2x10 on mojo hd help
    By stejekyll in forum Ibis
    Last Post: 01-30-2013, 10:57 PM
  3. Can i run a 2x10 front mech with a 3x9 shifter?
    By fredb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-25-2012, 11:03 AM
  4. 08 s-works fsr 2x10 dmd mech?
    By jhbikeboy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-12-2011, 01:40 AM
  5. 2x10 front mech on Altitude RSL
    By dclxvi in forum Rocky Mountain
    Last Post: 05-11-2011, 07:14 PM
