zero stack headset for the F1 jedi?- Mtbr.com
Results 1 to 7 of 7
    Reputation: katsooba's Avatar
    Nov 2008
    hey guys, been thinking about lowering my front end a little on my Jedi,
    i have the 08 Large F1, i wanted to know if anyone has any experience with the Cane Creek ZS-3 zero stack headset with the F1?
    i currently have the RACEFACE diabolus headset and that thing is huge
    thanks!
    17' Canfield Jedi 27.5" - The fast just got faster!
    15' Canfield Balance - The go to guy of the bike world!
    Commit or eat sh!t
    Reputation: Cable0guy's Avatar
    No ZS headset will fit. Regular 1 1/8" only. Easiest thing is to get the Canfield stem and/or flat bar to lower the bar height. If you want to change the headset, Crank Bros is lowest at 21mm (but is a crappy headset). Acros AH2 is next at 25mm. King, CC, Hope, FSA, etc. are all around 29-31mm.
    Reputation: bullcrew's Avatar
    Jan 2005
    CANFIELD stem and deity blacklabel bars.... I should have this set up by next week.....
    My Sponsor House
    "I dont make memories, I make History."
    CANFIELD - AVALANCHE SUSPENSION - SCHWALBE - TLD
    Nov 2008
    CANFIELD stem on a marz 888 ?
    Nov 2008
    what makes the headtube ZS compatible ?
    it looks about the same as the regular headset, just with smaller parts
    sorry for my headset n00bness
    http://www.canecreek.com/component-h...k&product=zs-3
    Commit or eat sh!t
    Check the specs on the CC site for inner and outer diameters for both the headtube and the headsets. That is how you check for compatibility.
    Canfield Bikes
    Reputation: flymybike's Avatar
    A 1.5 head tube is able to run a ZS HS. Not 1 1/8" HT.
