Wheelbuilders with a Riot ?s- Mtbr.com
Results 1 to 5 of 5
    Reputation: OwenM's Avatar
    Oct 2012
    Forget it.
    Jun 2018
    I can't speak to the actual bias, I typically eyeball it and then maybe pull the calipers out to confirm. My Riot currently has a pair if WTB asyms on it that I built up and I have zero issues with the asym and generally get to run tensions that are at the very least closer in tension to each other.
    In theory an asymmetric rim will allow you to run the same spoke length and spoke tension, dishing would just pull tension on one side slightly higher/lower but leave the relative tension closer to the same on each side.
    Hypothetically without having a truing stand you could just throw the new wheel in the frame, measure the difference in offset from center and then go around the wheel tightening/loosening just one side by equal amounts (half turn each go around until close, then quarter) until you measure the wheel to be centered in the stays.
    Just my 2 cents on how to quickly and easily do it yourself.
    Oct 2015
    Asym is designed to have near equal spoke tention depending on which wat you offset the dish, it could make it better or worse.
    Reputation: WHALENARD's Avatar
    Feb 2010
    You could fashion a dishing tool with a straight edge and 2 blocks/spacers to measure the difference on your existing centered wheel. With that you could talk to your wheelbuilder and figure what would work best to build with.
    It is no measure of health to be well adjusted to a profoundly sick society.
    Feb 2010
    ^ Actually you could accomplish that with merely a straight edge and a tape measure/ruler. Push the staight edge up to axle from rim edge to edge. Measue the distance on both sides to the axle cap. Substract them and you'd have your bias.
  1. Wheelbuilders - your source for parts?
    By RTM in forum Wheels and Tires
    Last Post: 11-12-2012, 01:58 PM
  2. Somewhat the wrong forum - Charlotte NC WheelBuilders?
    By jbsmith in forum North & South Carolina
    Last Post: 07-10-2012, 05:37 PM
  3. Attn: Wheelbuilders!
    By Cayenne_Pepa in forum Wheels and Tires
    Last Post: 04-19-2011, 11:30 AM
  4. local wheelbuilders gta
    By sm4k in forum Eastern Canada
    Last Post: 03-26-2011, 06:09 PM
  5. Great wheelbuilders?
    By Diggidy in forum Wheels and Tires
    Last Post: 02-03-2011, 04:35 PM
