Riot rear triangle tolerance- Mtbr.com
Results 1 to 2 of 2
    Jun 2018
    Quick question, I know that it is a generally accepted that the Riot can run boost or non-boost. However, does anyone have any idea how wide the rear triangle can be before its TOO wide and out of tolerance? Right now when I put my rear wheel in there is more that a little slop, it can freely not touch either side of the triangle by a pretty wide margin. The axle pulls everything back together, but I need to squeeze both sides to even get it to start threading.
    Quote Originally Posted by Fancy View Post
    Mine has done that since I got the frame (2015). With 12/142 rear-end. Never been a problem beyond trying to line up the axle and dropouts when removing/replacing a wheel trailside.
    Wouldn't call the gaps on mine 'wide margin', but there is maybe 5mm of space on each side.
  1. Replies: 4
    Last Post: 05-23-2014, 09:02 AM
  2. 2012 Niner Jet 9 RDO rear end tolerance issue
    By goiko in forum Niner Bikes
    Last Post: 05-24-2013, 04:21 AM
  3. Replies: 7
    Last Post: 07-05-2011, 08:01 PM
  4. Zero Tolerance Policy
    By blaklabl in forum Arizona
    Last Post: 04-22-2011, 03:17 PM
  5. Enduro rear triangle vs. SX Trail rear triangle
    By Scary Mc in forum Specialized
    Last Post: 03-30-2006, 04:04 PM
