Replacement BB for Canfield cranks?- Mtbr.com
Results 1 to 6 of 6
    Aug 2010
    What BB type fits Canfield cranks?
    I tried to install a GXP BB and the small flat washer/dust cover that covers the drive side bearing was too small to slide over the axle.
    The description on Canfield’s site says “GXP style BB included”.
    Aug 2010
    Anyone?
    Mar 2014
    The base level sram gxp has always been fine for me... typically lasts 12-15 months, cheap and easy to change.
    Dec 2011
    Bump-o-quiz
    What's over that wave-washer used with sram GXP bbs?
    Canfield bb does not need it as duster seal holds firmly in place, so canfield cranks not equipped with that.
    Changing to original gxp means someone need to get that washer somewhere.
    2nd: had anyone dismantled canfield bb and replaced bearings?
    Canfield Bikes
    Reputation: flymybike's Avatar
    The GPX BB is the replacement for the stock Canfield BB. The cranks pinch the non drive side bearing so the drive side just floats. The washer from Canfield is to fine tune the chainring spacing. The wave washer (shown above) just takes up space without tensioning anything.
    https://canfieldbikes.com/
    Building bikes that make you smile!
    www.mtbparks.com
    All Bike Park, All the time.
    Reputation: katsooba's Avatar
    Nov 2008
    i have been using a sram gxp for the past 3 years with the Canfield cranks, works fine for me.
    never had any issues with bearings or cranks like that
    17' Canfield Jedi 27.5" - The fast just got faster!
    15' Canfield Balance - The go to guy of the bike world!
  1. Replies: 19
    Last Post: 08-04-2016, 12:02 PM
  2. Cranks Cranks Cranks..BB30?
    By 29or6to4 in forum Singlespeed
    Last Post: 05-26-2012, 02:13 PM
  3. BB replacement vs BB bearing replacement
    By mrankin in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-11-2008, 06:44 PM
  4. Cranks, cranks, cranks!
    By notsofastanymore in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-18-2005, 09:58 AM
  5. cranks, cranks, cranks, ugh!
    By Motivated in forum Weight Weenies
    Last Post: 11-02-2004, 05:54 PM
