Re-painting the links on a 08 Jedi ?- Mtbr.com
Results 1 to 11 of 11
    Reputation: katsooba's Avatar
    Nov 2008
    Hello everyone!
    as u come to know i own a 08 F1 Jedi, and the blue paint on the rear linkage is starting to peel away,
    i want to take out the links and repaint them, maybe white to fit the bike theme,
    is there anything special i should know before taking out the links? anything complicated on the bolts? or its just a regular screw out the bolts and thats it?
    anything that might fall apart there?
    and would a regular paint remover remove the paint from the links?
    thanks
    Eli.
    17' Canfield Jedi 27.5" - The fast just got faster!
    15' Canfield Balance - The go to guy of the bike world!
    maker of trail
    Reputation: essenmeinstuff's Avatar
    ask the canfield guys, pretty sure they'd be more than happy to help you figure it out!
    Nov 2008
    i was hoping maybe one of them could share the info upon the internetz
    im pretty sure its a simple bolt on from both sides, but i dont want to get surprised by some hidden spacers or such
    Jun 2005
    all normal bolts and easy to take the links off, shock out 1st then the bottom link then the top
    Nov 2008
    thank you very much BW !
    i will post pics of before and after once ill make the change
    Canfield Bikes
    Reputation: flymybike's Avatar
    Been on the road. The links are easy to remove, nothing wierd. When you get the links off, the bearings need to come out. The strongest coating is powder coat other than anodizing. Be careful with the upper link so you don't bent it when pressing the bearings in and out. The paint stripper isn't good for the bearings either. Overall it's a easy job to paint them, have fun.
    Nov 2008
    Thanks for the reply
    i have a bearing puller that will make my job easy at that, so i guess they wont get damaged while repainting, while at it maybe i will check\replace them if they need that.
    im thinking thinking what color to paint the links, nothing special comes to mind, i guess ill stick to my white color scheme
    ill post pics when done!
    thanks!
    Nov 2008
    okay, made some progress today
    removed the links, the bearings and the color, now just waiting for the links to come back from paint
    removing the links was pretty easy, took me about 5 mins to remove the links and pull out the bearings, 20 more mins to remove the paint
    all the bearings are in great shape, just like new
    Nov 2008
    well, today i got the links back from painting
    this is how it looks now
    Nicely done! Reminds me of my first Jedi
    Nov 2008
    thanks! i really love this bike with this setup
