question for jedi owners!- Mtbr.com
Results 1 to 8 of 8
    hi
    I'm riding a jedi with fox 40 and it seems that the fork smashes the brakes and gears housing
    did some one try to pass the cables through the "F1" shape at the head tube to keep the fork from touching the cables?
    thanks
    do you have fork bumpers on there? have you considered moving them?
    they are there but still its happen
    should know better.....
    Reputation: neverwalk's Avatar
    May 2005
    Make sure the bumpers are lined up so the "fat " part of the bumper is what is hitting the frame, and position them so that the lines are above or below the contact points, so the bumpers themselves don't mash the lines.
    they are moving all the time
    do you think that i can use the "f1"shape to pass the cables through?
    so what do you say?
    May 2005
    I wouldn't. The angular/sharp nature of the cut out might wear through the cables from vibration and bouncing and turning.
    thanks
