Loosening Riot Pinchbolt- Mtbr.com
Results 1 to 5 of 5
    Oct 2017
    Hi all,
    Could anyone confirm which direction the Riot's rear axle pinchbolt should be loosened? I need to get my rear wheel off for a cassette swap - this is the first time I've needed to pull the wheel in a while, and the pinchbolt is quite stiff.
    If I remember correctly, the pinchbolt unthreaded clockwise when facing the non-drive side, but I just wanted to be sure before using more force.
    Thanks.
    Reputation: chestont's Avatar
    Both the pinchbolt and axle are threaded normally. When you are facing the head of the bolt, clockwise to tighten and counter-clockwise to loosen.
    Sent from my Pixel XL using Tapatalk
    Oct 2015
    If you're looking at the bolt (bike upside down)its counter clockwise. Same if behind the bike, unscrew to the left.
    Reputation: acfsportsfan's Avatar
    Oct 2017
    Thanks for the info - I just vaguely remember the bolt being reverse-threaded and wanted to be completely sure before starting to really wrench on it.
  1. Help adjusting pinchbolt / split shell EBB
    By herynkc in forum General Discussion
    Last Post: 11-14-2013, 05:24 PM
  2. case of loosening spokes
    By RoyBell in forum Wheels and Tires
    Last Post: 07-09-2011, 01:06 PM
  3. QR loosening problem
    By inkybandit in forum Singlespeed
    Last Post: 01-20-2011, 07:11 PM
  4. Pinchbolt Advice...
    By Meat Foot in forum Singlespeed
    Last Post: 06-29-2007, 02:48 PM
  5. pinchbolt or expanding ebb
    By Carleton in forum Singlespeed
    Last Post: 04-23-2005, 06:23 PM
Members who have read this thread: 18
