DHF 2.5 WT in Riot?
Printable View
  • 11-25-2018
    racefit
    DHF 2.5 WT in Riot?
    Will it fit mounted to a 29mm internal rim?
  • 11-25-2018
    Raleighguy29
    I ran a 2.4 dhr2 on the back of mine on a i9 Enduro 305 rim. I think itís a 30-32 internal. No problems.
  • 11-25-2018
    Glenngineer
    I ran a regular 2.5 on the Canfield wheelset, ~25mm inner width, and I got enough rub between frame flex, wheel flex, and muck and crap in there that I downsized to 2.3.
  • 11-27-2018
    hitechredneck
    short answer.
    Yes
  • 11-28-2018
    racefit
    Iím also considering a 2.5 Aggressor in the rear. Although there is a recent post around here saying the Aggressor measures wider than the DHF 2.5.
  • 11-29-2018
    Dr Gigi
    Should fit fine. I'm running a 2.35 HD in the rear (measures almost the same as a 2.5 DHF) mated to 30mm ID rims and have plenty of space.
  • 11-29-2018
    hitechredneck
    Also tested and was fine.
