Converting Canfield front hub to 110 boost- Mtbr.com
Results 1 to 2 of 2
    Sep 2016
    New question here. Converting Canfield front hub to 110 boost
    Hi, I have canfield whells with canfield hubs and lately I've purchased
    a DVO boost fork.
    Does any one ave any idea what end caps I need to convert front hub from 100 mm to 110?
    I was searching over the internet for boost adapters and the DT (240) ones look very similar to canfield's end caps but I can't be sure about it.
    Jul 2017
    I'm convinced that Canfield hubs are the same as Formula hubs.
    https://www.formulahubs.com/product.php?t=3
    The Canfield front hub is probably the Formula DC-71. So if you can find a way to make a DC-71 into a Formula DC-711, then you can do that to your Canfield front hub.
    I don't see anything on the Formula hubs web site available to do that though.
  1. Quick question converting non boost DT to boost spacing
    By Doctorsti in forum Wheels and Tires
    Last Post: 06-01-2018, 02:20 PM
  2. 2017 Pike Non Boost vs. 2018 Pike Boost....Boost worth it?
    By bwj75 in forum Shocks and Suspension
    Last Post: 11-09-2017, 02:21 PM
  3. Boost to non-boost for SRAM 716 15x110 front hub?
    By Doug in forum Wheels and Tires
    Last Post: 10-12-2017, 05:18 PM
  4. Is it possible X0 15*100 Hub to 110 Boost?
    By HrLee in forum Wheels and Tires
    Last Post: 10-18-2016, 11:19 AM
  5. Convert hub to Boost 110
    By Bikerbob.com in forum Surly
    Last Post: 07-18-2016, 12:22 PM
