Canfield Site Down - What New Bikes??- Mtbr.com
Results 1 to 7 of 7
    Went to the Canfield site. It was down stating that a new site with new bikes is in the works.
    Anyone got any idea of WHAT new bikes? I did hear that newer beefier links were coming out but I heard nothing about new bikes.
    should know better.....
    Reputation: neverwalk's Avatar
    May 2005
    For sure, the Jedi's are getting a new rear triangle. Rear tire clearance was an issue for some riders, so the rear triangles may get reworked across the line, but that is pure speculation.
    Jedi changes: rear tire clearance - dropouts - and yoke connector tube
    From the horse's mouth.
    wcr
    wcr is offline
    May 2005
    Candiggle changes?????
    I know the lower link in the One linkage is being stiffened up. Curious if there are other changes though.
    Reputation: Playdeep's Avatar
    Mar 2005
    They are stiffening up the lower link for the One....which is the same lower link on the Diggle. That doesnt require a change of the rest of the frame.
    Ask lance and chris about the Jedi bikes changes. If you are lucky enough to get your hands on one when they are in stock.
    7MGTE
    Reputation: supramk388's Avatar
    I could tell you but then I would have to...
    Here is the "known" changes that are not so hush, hush.
    Jedi updates
    http://forums.mtbr.com/showthread.php?t=462785
    Maybe the changes are coming soon like the site says? Might want to wait and see or check back from time to time on the site.
