Canfield Brothers Lucky's are in!- Mtbr.com
Results 1 to 63 of 63
    Canfield Bikes
    Reputation: flymybike's Avatar
    Here is the first Canfield Brothers Lucky frame. Just built it up and spent the weekend in Moab.
    Geometry
    Adjustable Travel 7.09 (180mm) to 8.15 (207mm)
    Bottom Bracket Height 14
    Chain Stay Length 17.0
    Head Angle with a 570mm A to C Fork (8) = 66 deg. (7) = 67 deg.
    Small:
    Actual Seat tube 15
    Effective Top tube 22
    Medium:
    Actual Seat tube 17
    Effective Top tube 23
    Large:
    Actual Seat tube 19
    Effective Top tube 24
    Frame Weight 11.25lbs (medium with Fox DHX 5.0)
    Rear Hub size 150 x 12 thru axle
    Head tube Length 125mm
    Head Set Size 1.5
    Seat Post Diameter 27.2mm
    Seat Collar Diameter 31.8mm / 1
    BB Shell 83mm w/ ISCG Tabs
    BB Size 83 shell x 128 spindle (fits all types)
    Max Tire Size 2.7
    GOD SPEED # 58 # 69 RIP
    Reputation: pvflyer's Avatar
    Dec 2004
    Looks really nice, is that 1.5" headtube?
    regards
    Leash Law Enforcer
    Reputation: Pinch's Avatar
    Nice looking frame!
    Dec 2004
    Quote Originally Posted by pvflyer
    regards
    Never mind,,,,,,
    a tight kick sound
    Reputation: boone's Avatar
    Awww man!
    That looks soooo much better than the last proto I saw!
    I knew that was gonna be a killer bike
    Very nice.
    Now how about some ride reports?
    What does that WB come out to?
    Is the frame aluminum?
    Any idea of the seat tube angle?
    Could you take a pic of the bike directly from the side for me?
    That bike looks really nice my friend
    Booner
    Canadian Invasion
    Reputation: Phi.Design's Avatar
    Dope show....nice work!
    www.derbyrims.com
    Reputation: derby's Avatar
    Looks great! Nice to see the dw-Link in another flavor.
    conjoinicorned
    Reputation: ferday's Avatar
    DW did NOT invent the parallel link.
    what would rainbow unicorn do?
    gmoney was gmoneybike
    Reputation: ghashmi's Avatar
    Boootiful
    What a beautiful bike. Looking forward to hearing more about it.
    Were looking at balz
    Adjustable Travel
    Quote Originally Posted by flymybike
    How is the adjustable travel accomplished?
    Canfield Bikes
    Adjustable Travel
    The Lucky adjusts from 7" to 8" with two mounting holes for the shock on the upper link.
    Canfield Bikes
    More Pictures
    Had a request for more pics so here you go!
    Canfield Bikes
    a few more pics.
    The rear triangle uses a internally ribbed tubing, as does the support tube for the upper forward pivot, for increased lateral stiffness and durability. The bearing in the upper link are 20 x 32 x 7mm bearings and the lower link runs a custom double row 20mm bearing with extended inner race to eliminate the need for washers. The rear end runs a 150x12 hub and the frame comes with the axle, a standard Canfield replacable hanger and a Saint compatable hanger also. The finish is XTR Grey hard anodized and has graphics polished into the aluminum before anodizing. The logos are laser etched into the anodizing, giving you a durable finish with no need for stickers.
    Feb 2006
    Thanks for posting those up, looks great, am loving the details. Can wait to get my hands on one.
    Canadian Invasion
    Damn that sh*t is hot to death. I love the mint bars!
    That is one beautiful bike. It just all flows together to create a masterpiece.
    "No, you're going to be promoted to GLG-20."
    user-created
    Reputation: singletrack's Avatar
    I was really confused as to what was going on in this pic till I saw the file name. Anywho...
    Feb 2006
    Tech question alert!!!!!
    Okay, the arrival of my frame in iminent (maybe next week? Any updates on that?) and I'm looking at spring rates and trying to get an idea of shock set up...
    I'm going to run the bike in 7" mode predominantly. I'm ~205-210lbs so I'm guessing the leverage ratio in that mode is better suited to my weight. However, how does the leverage ratio vary through the stroke in 7" mode? Is the linkage designed to have a progressive rate and ramp up at end of stroke or is it linear and you use the adjustments on the DHX to make it as progressive as you like?
    Canfield Bro's, what did you end up with for settings after your first ride? Did you spend a lot of time adjusting the shock? It looks like I'll need a 450 spring, or maybe a 400 with pre-load if I want a bit more sag.
    Finally, does the difference in shock mounting for the 7" travel affect BB height and HA? I've got 170mm cranks to run but could change them for 165mm if the BB is too low.
    Thanks.
    Jon.
    Canfield Bikes
    Quote Originally Posted by jon_boy
    Thanks.
    Jon.
    Hey Jon
    I tested the Roco on the Lucky for about 3 months last season and it's a really good match for the bike. Alot smoother than a Fox but I like the Fox for more AM type riding.
    The Luckys are (edit) in and then we need to inspect and inventory everything. I'm guessing mid Febuary for delivery.
    I run a 450# spring for 8" mode and weigh 150 lbs. In 7" a 450 works for Chris weighing in at 180-185. I think you should start with a 500 and go from there. The Lucky is VERY progressive so we turned the propedal off, backed the compression damping all the way off and slowed the rebound to my liking. Chris likes it with a little less rebound than I do, being more of a racer than a hucker.
    The BB is 14" in 8" mode and drops to 13.7" in 7" mode.
    The head angle is 66 degrees in 8" mode and is 65.5 degrees in 7" mode with a 570mm tall fork. If you can, run 165 cranks.
    Hope I answered everything for you. Let me know if you've got more questions or give Chris a call. 801-548-2556
    Feb 2006
    Thanks for the information. Just trying to get all the parts for the build together.
    Mar 2006
    does anyone knows why the left and the right support on the rear swingarm is different? one is a tube(left) and the other is just a slab of metal strip?
    cheers
    Feb 2006
    That's to clear the chain.
    The finish looks top quality, i'm diggin' the lazzer etching.
    two quick questions,
    what's the price?
    Is chain growth an issue?
    Canfield Bikes
    Price is $2349 frame and Fox DHX 5.0.
    Chain growth isn't an issue, it has about the same about as a M-3.
    I Just Ride....
    Reputation: mtbbrian's Avatar
    Sep 2002
    Looking Good!
    Brian
    Artistic Mountain Bike Photography
    My MTBR Gallery
    "I Ride my bike, to Ride my bike...."
    From a Zen proverb
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    I posted this in another canfield thread too but what is the appropriate use of the Lucky? FR, AM or mini-DH?
    What is the weight of a built one and desired fork travel?
    I ride a bullit now as a do everything, AM/FR bike and was looking for a similar thing. Would the balance be a better idea? I have no idea what that bikes niche is either.
    thanks for the knowlege
    MTBR Posting Guidelines
    calories>electrons
    Feb 2006
    I think I saw it written somewhere that the Lucky is DH/FR and the Balance is DJ/AM/FR. The Balance is built to be strong and will take the abuse that DJ/FR dishes out but can be built to be an aggressive AM rig.
    I think Lance said that Chris is going to race the lucky this year.
    Canfield Bikes
    Thanks Jon_boy. What he said.
    Feb 2006
    What's the latest thoughts on when these frames might land at DropNZone? There's a pile of parts waiting to go on it.
    north van
    Nov 2006
    ha ha! your everywhere
    hey chris, any idea if my frame was shipped yet?
    Canfield Bikes
    A bunch of Luckys are going in the mail today. DropNZone should see them wedsday.
    We just updated www.canfieldbrothers.com too.
    CHEERS!
    Feb 2006
    I got the call from Allen earlier. STOKED!!!!
    I will hopefully get down there before next weekend to pick it up. I'll post up pics once it's home.
    Feb 2006
    Here's my bike, I picked it up today;
    Feb 2006
    Here's some more....
    Too Much Fun
    Reputation: benja55's Avatar
    Aug 2005
    Damn
    ...That rig is PURE BURL. Nice.
    And thx for the ride pics. Both looked sketchy as hell!
    Post more if you got 'em!
    - -benja- -
    Canfield Bikes
    Here's a few more pics from Moab. Was great to get out of Jackson's cold hell for a bit. Chris will be riding in Bountiful this weekend, hopfully getting a few more pics. It's looking pretty dry.
    He just got his Lucky built up, 40lbs and could shave a couple more easily. He'll get some bike shots this week too.
    Too Much Fun
    Aug 2005
    Good job! Holy NUTsax!
    1000x thx for posting some more. Those are ill. Something about those angles and the fact that I'm still a pretty toy rider when it comes to big hucks and big air... Yeah, when I look at those I'm not totally sure how I'd land them.
    Damn. Nice shots, nice riding, nice bike.
    - -benja- -
    Feb 2006
    My bike ended up being around 42lbs. My wheels are not the lightest and a lb could be easily lost there and I could go to an E13 LG1 guide to loose some more. The Ti spring is on, so it does make 40lbs realistic.
    I really like the fact that this frame has a nice easy light rear thru-axle set up. That shaves a lot of weight right there. No stupid steel axles for this frame.
    Broken
    Reputation: Gleeke's Avatar
    Jun 2005
    FLYMYBIKE
    ANy pics of the red links?
    Lucky owners..How are you liking you bikes?
    Canfield Bikes
    Stole it from somewhere......
    Guys, awesome bike...congrats!
    Quick question: Where is the best place to get one? Should I just call up Canfield directly? Will they just ship to my home?
    I want a XTR Grey with red links if possible.
    TIA.
    yeah, call them directly
    I think that is how most people get their frames. The number is of course on their web site.
    Broken
    Jun 2005
    Quote Originally Posted by Snowpug
    TIA.
    Yes they will. Chris is awesome to deal with! Super helpful.Just call, pay and you don't wait very long. I'm chomping at the bit to get mine together.
    Thx guys.
    My lbs just left a message with them yesterday so we are awaiting a call back. I want a grey with white links now!
    north van
    Nov 2006
    thief! you stole my pic
    btw, great bike
    Reputation: motherfudpucker's Avatar
    hey chris, do you have any of the original proto looking lucky's. the steel ones with the round tubes. like the blue one you introduced last year on the forums? i think it was in the writeup where you were dropping off of a loading dock,,
    Theres two things wrong with the fire service today.... EMS and PMS
    EMS i can deal with....
    Canfield Bikes
    Quote Originally Posted by motherfudpucker
    This is Lance. I have the one and only. It's in our Canfield history collection. It's been a great bike. I need to repaint it, it's had a hard life but will never die!
    GRAVITY IS GOOD
    Reputation: HOFFMAN223's Avatar
    Hey Lance, did you say something about a history collection??? I would love to see some pictures of historic Canfield creations? Come to think of it, I'm sure alot of other people would too!
    Broken
    Jun 2005
    Quote Originally Posted by HOFFMAN223
    DITTO!!!
    BTW can we see The ONE?
    Canfield Bikes
    Heres just a few from the collection, not all ours, but shows the progression of our frames.
    First bike we built wes the "Big Fat Fatty Fat". 12" front and rear, 17" chainstays, 26 -24 wheel combo decked out in retro gear. I still have it just as the picture shows.
    The next bike was the Fatty Fat, 10" travel with a progression link.
    The next was the first in the Signature Series bikes. Chris built this one for me to ride in the Red Bull Rampage. My first ride on it was the first day of practice with way too many cameras but it was golden. One of the finest bikes I've had and the first steel front we made. The last shot, hip sequence, is the third day on that bike.
    One of the last Signature frames was Josh Benders. It has a custom head angle for a Super Monster, steel front and double thick rear. It was 18 lbs, frame only, but perfect for Bender. He still has it.
    Then came the Formula 1 in 04-05. Refined in alot of ways, lighter, lower and slack and made the move to production with Pacific Cycles. We would have had to closed our doors because it wasn't reasonable to keep doing business that way we had been. Now we are able to refine the bikes to a level we would have never had the time to if we where doing all the building ourselves.
    I'll post more on this later. I hope you enjoy it. Cheers
    good stuff
    Thanks for the history pics, always neat to see the evolution of a product. Do you remember who took that last sequence shot? They did a fantastic job and I am curious how they accomplished it.
    Facken Righteous
    Canfield Bikes
    Not sure who shot that picture but it's one of my favorites. The "Billy Goat Line" in Virgin, had to chop out a part of the cliff to get my bars to clear to even get to the hip. Techy line for sure and the runout has a fluffy burm and if you blow it theres a cliff right below.
    Heres another fovorite from the Test Of Metal in Moab. Jumpsing over the rock in the left corner. Don't want to case that one.
    https://gallery.mtbr.com/data/mtbr/5...r_Rock_low.JPG
    I mentioned Bender but missed the pic. Here it is.
    And one of me and my bro, Chris at Mushroomdrop.
    GRAVITY IS GOOD
    WOW! Amazing stuff Lance, thanks so much for sharing the wealth! I am always excited to see prototypes and the evolution of designs. Many times the early incarnations of certain bikes are more interesting than the final production runs, fortunately for you guys that isn't the case. Your bikes just seem to get better and better!
    ya two of my buddys have diffrent canfields and i must say i am down with canfield thats for sure
    Feb 2006
    Minor spam, but I'm looking to sell my Canfield Lucky frame. I need to liberate some $'s for some home projects that I'm in the process of doing.
    http://classifieds.mtbr.com/showprod...=17131&cat=500
    Let me know if anyone is interested.
    Feb 2006
    Bump for this... now $1300 and keen to sell... make me an offer, I need the $'s.
    rr
    rr is offline
    I don't do PC
    Reputation: rr's Avatar
    Broken
    Jun 2005
    Looking to replace my 2005 66r on lmy lucky w a new fork. Any opinions on the Travis 18o, Totem and Fox 36 would be welcome.
    7MGTE
    Reputation: supramk388's Avatar
    Freaking SICK! Awesome pic Thanks
    I heart the drops
    Reputation: giantsaam's Avatar
    I am saving up my pennies for this one so hopefully it will be my new ride before next season. That is still one of the sexiest bikes I have ever seen.
    "its not how slack your head angle is, its how you ride the bike"
    maker of trail
    Reputation: essenmeinstuff's Avatar
    Sorry for dragging this old thread out of the doldrums...
    Its looking like I'll be picking up a lucky frame in the next few weeks
    So I have some questions!
    Geometry
    Small:
    Actual Seat tube 15
    Medium:
    Actual Seat tube 17
    Large:
    Actual Seat tube 19
    Head Set Size 1.5
    Max Tire Size 2.7
    Here it says 7" mode steepens the HA, yet further down this is contradicted, so, ummm which is it?
    Given a rider weight of 180-190ish lbs, what shock spring rates would work in 7" and 8" mode? All round use, aggressive trail, rocky rooty east coast DH, and freeride...
    Does the frame play nice with air shocks like roco WC etc?
    Thanks and hopefully a canfield owner soon
    I was running my with a evolver for a bit, and I wouldn't recommend. Its really much better suited for a coil.
