Bros cranks and Chris king bottom bracket.- Mtbr.com
Results 1 to 5 of 5
    Reputation: Raleighguy29's Avatar
    Jan 2014
    So Iím on my 3 rd bb in 600 miles on my nimble9. I run the bros cranks on all 4 my canfield bikes. I usually just buy a cheap sram gxp bb. But I thought I would try a king one and hopefully get a lot more life out it. The bb didnít come with any spacers or shims. And when I install my cranks they wobble. So what am I missing.
    Reputation: ChvleSS956c's Avatar
    Chris king bb usually have an adapter for certain cranks, you need one for the candied cranks since they are made to use the gxp standard, which on one side is 2mm smaller, so there should be a plastic adapter kit for the ck bb
    Sent from my iPhone using Tapatalk Pro
    Jan 2014
    Thanks thatís what I was thinking but wasnít sure
    The original BB that comes with the cranks is realy good imho (whoever actually makes them). First BB to last longer than one season on my DH-bike.
    Regarding the wobble, are you sure youīve fastended the bolt on the non-drive side? Sounds obvious, but of the four set of cranks that I own, one was noticable more difficult to fasten (the last few turns).
    Oct 2017
    Hi, guys
    I need to replace self extracting crank bolt for bros cranks.
    Not sure which I need.
    Will this one fit? Any suggestions?
    Thanks.
    FSA ML054 Crank Bolts M15
  1. Chris King seals and bearing repair for Bottom bracket 68/73mm 24mm
    By ReturnOfTheMTB in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-18-2017, 11:47 AM
  2. Chris King Spam: Brand New Chris King Rear Hub CHEAP
    By jonshonda in forum Wheels and Tires
    Last Post: 12-28-2016, 11:42 AM
  3. Replies: 10
    Last Post: 11-13-2007, 07:36 PM
  4. Difference between Chris King ISO and Chris King Classic
    By Huck Your Meat in forum Wheels and Tires
    Last Post: 09-26-2007, 03:00 PM
  5. The King is here! not that "King", Chris King
    By 32seventeen in forum Singlespeed
    Last Post: 04-05-2004, 07:36 AM
