2018 N9 Geo/reach Question- Mtbr.com
Results 1 to 5 of 5
    Professional Crastinator
    Reputation: Fleas's Avatar
    I just switched from a large size 2013 to a XL 2018 N9.
    I did not change any component except my handlebar stem. The old frame had a 90mm stem. Admittedly, it's kind of an XC setup. That's another reason for the switch to XL: less XC, longer, slacker, blah blah blah...
    L 2013 ETT = 609mm
    XL 2018 ETT = 650mm
    Swap in a 45mm stem for a 90mm stem and I should be pretty close to where I was, right?
    Wrong.
    The distance from the back of the saddle to the bar clamp was 34".
    The new setup was 33". That means I should have bought a 70mm stem.
    How did this happen? I obviously overlooked something.
    Possibly because the seat post is not extended as far on the XL frame? I doesn't seem like that is the case, but maybe the top tube is a tad lower on the '18.
    This question may never be answered since I didn't measure the saddle position relative to the BB on the 2013. ...and my eyeball on these pix isn't telling me much. Pedaling seems to be normal.
    I also took out a 5mm spacer from under the stem to account for the 5mm longer headtube, but the bars felt too far below the saddle so I put it back. Fuzzy math?
    2013
    2018 N9 Geo/reach Question-2013n9.jpg
    2018
    2018 N9 Geo/reach Question-2018n9.jpg
    Thanks,
    -F
    It's never easier - you just go faster.
    Reputation: coleam's Avatar
    The missing component is that the actual seat tube angle went from 70.9 on the 2013 to 72.8 on the 2018. So at a given saddle height, your seat will be a bit further forward on the 2018 vs. the 2013.
    Quote Originally Posted by coleam View Post
    That's probably it. The actual, not the effective. As the saddle is raised, it goes back farther on the 2013.
    Adding a dropper will probably not help, either, unless I want to spring for a set-back dropper.
    Thanks.
    -F
    Quote Originally Posted by Fleas View Post
    Thanks.
    -F
    Yeah, a dropper won't make a difference. There aren't that many setback droppers, and none of them have enough setback to make a difference. Looks like you already have 15-20mm of setback with your current post, and I don't know of any droppers with more than 25. Also looks like your saddle is slid all the way back already. I would say try riding with the current setup for a bit, and if it's too uncomfortable, try the longer stem.
    Sent from my SM-G950U using Tapatalk
    Well I did get the dropper and the 70mm stem and it got me out to 33-1/2" so I rode it many miles this past weekend. The '18 frame has that real steel feel, as opposed to the '13 which felt like a stiff DJ frame. It was nice! And the slacker head angle saved me at least once for sure.
    I think the BB is just a tad lower - could be as much as 3/8" - but not at risk of pedal strikes unless I am just careless.
    I still kinda want that last 1/2" of reach back, so maybe an 80mm stem is in my future.
    -F
  1. Replies: 4
    Last Post: 03-28-2017, 07:34 AM
  2. Compare Race Geo vs Modern Slack Geo
    By Afun in forum General Discussion
    Last Post: 08-17-2016, 06:44 PM
  3. Honzo/N9/Yelli geo at xc weight?
    By Clink in forum 29er Bikes
    Last Post: 12-03-2013, 12:01 PM
  4. whats the difference between hybrid geo and 9r geo?
    By jeffgothro in forum 29er Bikes
    Last Post: 04-14-2011, 08:15 AM
  5. Replies: 6
    Last Post: 11-12-2006, 05:19 PM
