2015 Canfield Brothers Riot 29er FS - Page 62- Mtbr.com
Page 62 of 62 FirstFirst ... 12525859606162
Results 6,101 to 6,159 of 6159
  1. #6101
    Oct 2017
    Quote Originally Posted by Darksoul View Post
    I have narrow wide oval 32t ring for 104bcd I have to get direct mount chainring!
    If you've already got a 4 bolt chain ring, you could use a spacer instead of the second ring.
  2. #6102
    Oct 2015
    I ran a 104 on a Zee crank set to get me riding. Direct mount gives a better chainline so less wear and no backpedal issues. The short chainstays make backpedaling a bit$$ your chainline is too off.
  3. #6103
    Apr 2014
    Quote Originally Posted by Cerberus75 View Post
    Yes I know this thing but I didnt back pedaling never 🤣🤣 thanks a lot I will converting in the future..to direct mount with correct chainring
  4. #6104
    Nov 2008
    Offering this -One of a Kind, set your bike apart. CUSTOM HOPE PURPLE AND LASER ETCHED CANFIELD LOGO ONYX REAR HUB 12x142 XD Hub. Non-Boost. Onyx instant engagement hubs are some of the best available. Less than 100miles. Got injured, no biking for me for awhile. Parting out my Canfield Riot. Message me if interested. $495 new. a Couple of small spoke nick shown in pics. $280 plus $15 shipping in the Continental US2015 Canfield Brothers Riot 29er FS-final1.jpg2015 Canfield Brothers Riot 29er FS-final2.jpg2015 Canfield Brothers Riot 29er FS-final3-chips.jpg2015 Canfield Brothers Riot 29er FS-final4.jpg2015 Canfield Brothers Riot 29er FS-final5.jpg2015 Canfield Brothers Riot 29er FS-final6.jpg2015 Canfield Brothers Riot 29er FS-only-receipt.jpg
  5. #6105
    Nov 2008
    Quote Originally Posted by jsalas2 View Post
    Offering this -One of a Kind, set your bike apart. CUSTOM HOPE PURPLE AND LASER ETCHED CANFIELD LOGO ONYX REAR HUB 12x142 XD Hub. Non-Boost. Onyx instant engagement hubs are some of the best available. Less than 100miles. Got injured, no biking for me for awhile. Parting out my Canfield Riot. Message me if interested. $495 new. a Couple of small spoke nick shown in pics. $280 plus $15 shipping in the Continental USClick image for larger version.
ID:	1228128Click image for larger version.
ID:	1228129Click image for larger version.
Name:	FINAL3 CHIPS.jpg
ID:	1228130Click image for larger version.
ID:	1228131Click image for larger version.
ID:	1228132Click image for larger version.
ID:	1228133Click image for larger version.
Name:	ONLY RECEIPT.jpg
    Bump
  6. #6106
    Sep 2018
    so - about my heel and derailleur problem: it looks better now
    shorter crank (170 instead of 175) and i switched from 12xGX Eagle (which I used as 11x to a 11x X0
    looks like my heels problem is gone. but its just about a few mm. And I just have shoe size 42EU/8.5US
    but I love this fun bike
  7. #6107
    Oct 2017
    Hi all,
    I recently was pulling my rear wheel on my Riot to replace hub bearings. Unfortunately I was a bit distracted, and instead of loosening the wheel I ended up tightening it (pretty dumb, I know). The axle creaked, and then moved about 1/8 to 1/4 a turn. I then realized what I was doing, and then actually loosened the axle.
    Is it possible I could have damaged something? I pulled the axle out, the only real difference I noticed was some slightly deeper than normal score marks from the axle head (Salsa deadbolt UL - for some reason it has spikes on the bottom). My normal torque is solidly tight, using one hand and a 6in hex key. I would estimate between 10-12nm. This unexpected tightening was still with one hand and a 6in hex key. I would be surprised if it was over 14-16nm.
    The top eyelet of my Topaz has also begun sliding horizontally for the second time. If I grab the shock and push or pull, the top of the shock will move horizontally slightly. DVO sent out new bushings and hardware which solved the play initially, however after one ride the movement is back. Has anyone experienced anything similar previously? I'm starting to wonder if the shock eyelet is narrower than normal, or if something is wrong with the frame mount.
    Thanks for any help.
  8. #6108
    Oct 2015
    Quote Originally Posted by Phoenix864 View Post
    Hi all,
    Try treading the axle with out the hub, grease it good and see if there is any area that sticks.
  9. #6109
    Oct 2017
    Sounds good, I'll pull the wheel (this time correctly) and try threading the axle. Sorry if I'm missing something, but what do you quite mean by "any area that sticks"? Additionally, would you recommend greasing just the axle threads, or the head and shaft too?
    Thanks for the help.
  10. #6110
    Oct 2015
    Just grease the threads. If the axle goes in easy its probably ok. If you feel any hesitation it may have some damaged threads.
  11. #6111
    Oct 2017
    I finally got around to checking the rear axle - the axle came out and went in really easy, the only "damage" I could find was some additional marking on the frame under the axle head (thanks spiked axle head).
    While everything looks ok to me, I definitely would appreciate a second option. I got some photos detailing the inside/outside of each dropout. Also, how much are you guys tightening your axles and pinch bolts?
    Thanks for the help and advice Cerberus75.
  12. #6112
    Oct 2015
    From the picks the threads look fine. I would not stress about the etching from the grooves on the axle. I just tighten both to hand tight, without weight as leverage. Use blue locktite on pinch bolt
  13. #6113
    Does anybody have any thoughts or impressions of using offset bushings on the rear shock?
    I love this bike but it suffers from the on it not in it feeling and Id like to do a little bit to rectify that.
  14. #6114
    Reputation: beer_coffee_water's Avatar
    Mar 2011
    Phoenix864, how have the Maguras performed in the Riot? Are you able to compare them to the ubiquitous Shimano brakes? That is what I am looking to upgrade from on my Canfield.
  15. #6115
    Oct 2017
    Sounds good, I'll definitely stick to nicely hand tight from now on. Thanks for the prompt help and reassurance.
  16. #6116
    Oct 2017
    Quote Originally Posted by beer_coffee_water View Post
    The Maguras have been excellent. I previously have run both a set of Shimano XTR M785s and SRAM Guide Rs. The MT7s obviously offer far more power than both (I think it would be difficult to find a more powerful brake than the MT7s), while also offering great modulation and lever feel. Lever feel is a bit softer than Shimano in the early part of the stroke (allowing for better brake feathering), before firming up quickly through the middle and end stroke for max power.
    Using mineral oil is a big plus for me, though I can't comment on how easy it is to bleed them (haven't needed it yet). The HC lever blades are shaped nicely and feel very solid, and the reach and contact point adjustments work well.
    I've only come across two concerns/issues so far - First is that the lever clamp screws directly into the composite lever body. This makes it really easy to strip the lever body threads, and since the lever body is one piece a replacement isn't cheap.
    Second is that the calipers are very difficult to align, even with thinner IceTech rotors. Even after my best effort I was still getting some slight rub. However, I couldn't notice it on the bike so it wasn't too big of a deal (the rub might have even gone away after wearing the brake pads a bit, though I haven't checked recently).
    That said, I would definitely buy a set of MT7/5s again over anything out of SRAM/Shimano. Their power is right in line if not greater than both Saints and Codes, while offering (in my opinion) a superior lever feel and using mineral oil.
  17. #6117
    Apr 2014
    Hi to all I changed my bushings in the frame on rear shock because the rear one has little play side to side now after 2 months again the rear ones have play side to side again!
    Im using dvo topaz
    maybe the frame has damage?
    or just the bushings its too soft?
    and when pump the bike feel gap in the rear shock when uninstalled the shock the frame arms has no gap or anything suspicious!
    I will try my friend dvo first and after I re lube all the bearing in the frame
    Is there someone with this problem with this frame?
  18. #6118
    Oct 2017
    Im using dvo topaz
    Interesting, I have a very similar problem. I can push the top of my topaz side to side slightly with it mounted in the frame. I've tried new hardware and bushings, but the movement persists.
    I've spoken to DVO about it, and someone there actually has the exact same problem on a riot with a topaz. They said that they would try some slightly wider hardware and get back to me. I'll update when I hear back. I hope there isn't some sort of widespread problem with the riot's shock mounts.
  19. #6119
    Apr 2014
    fail for sure for this nice bike and dvo which I love it so much and works great for what I do here in Greece!!
    please send me pm when you have news because I dont want to damage my frame and the shock!!
    thanks!!
  20. #6120
    Oct 2015
    Im going into the 3rd season with the same bushings on my shock. Its a different shock (Avy). And both of you have issues with DVO bushings leads me to believe that they are too soft. Unless both of you have wider spacing than spec. When the bushings are new are they a tight fit?
  21. #6121
    Oct 2017
    Even after installing brand new bushings and hardware I was still able to slightly slide the shock horizontally. When I measured the frame and shock with a set of calipers the numbers were relatively close to their listed widths, but obviously something is not quite within spec.
  22. #6122
    Apr 2014
    your frame has the bolu bearings or enduro maxx?
    maybe with bolu bearings has a different flex the rear triangle....
    I got a answer from Dvo this morning
    Sorry about the issue Phillip. That problems seems to be specific to Canfield frames. We have a Canfield frame in our demo fleet and have the same problem. Weve tried different brands of mounting hardware and after a few months, we get the same side to side play. We think it may have something to do with excessive flex in that rear triangle. Let us know if we can help in any other way and thank you for riding DVO!
    that answer doesnt fix my problem of coarse...
    I will send and the bros anyway for the record!
  23. #6123
    mjw
    mjw is offline
    Feb 2007
    My Topaz/DVO bushing were a loose this also, and cause cracking/popping/creaking in the rear end when the frame was being torqued and loaded.
    My issues went away and have not come back since swapping to Cane Creek.
    • 2015 Kona Explosif Ti
    • 2015 Kona Process 111
    • 2018 Canfield Riot
  24. #6124
    I'm with stupid
    Reputation: hitechredneck's Avatar
    Push 11-6 does not seem to have this issue.
  25. #6125
    I had DVO and RS and CC rear shocks when I had my Riot. The DVO hardware was always a little narrower than the othes and would do this also. I loved how the Topaz rode but it wasn't all ice cream and cotton candy goodness.
  26. #6126
    Jul 2017
    Anyone think the PUSH Low Friction Mounting Kit could fix the DVO Topaz/Riot problem?
    The end caps in the PUSH Low Friction Mounting Kit are actual metal, and not plastic like the DVO end caps:
    https://www.pushindustries.com/colle...n-mounting-kit
    I don't understand why the DVO end caps are soft plastic at that location.
  27. #6127
    Oct 2017
    Just got a response back from DVO. They'll be sending out some 22.2mm (vs the old 22mm) front hardware, hopefully it will solve the issue. I have been noticing some periodic popping and creaking under heavy load. I originally though that it was coming from the linkage, but after cleaning it up the noise was still there (unfortunately I didn't check which kind of bearings I had, sorry). It seems like it could be coming from this shock play. I'll definitely report back once I get the hardware fitted.
    Darksoul, did you speak to DVO USA, or your local DVO importer? I can definitely say that when I spoke to DVO USA they did not share the same option as what the message you got stated. Other shocks are being run on Riots for months without developing bushing play, so it shouldn't be related to the frame design.
  28. #6128
    Jul 2017
    Quote Originally Posted by A. Rider View Post
    Never mind, "Our kits fit Model Years 2000-2016 FOX Air Shocks and FOX Coil Shocks only".
  29. #6129
    Apr 2014
    I push the support button in the site I sent mail in usa support not my dealer here in Greece...
    ok I will send other message right now because this is very annoying....
  30. #6130
    Apr 2014
    k now understand riot frame Shock Specs 200mm x 57mm, (22mmX8mm and 36mmX8mm hardware)
    I have the cards from the box I installed!
    and dvo topaz I installed has 35.2x8 bushings rear and front 22x8
    In the site the 36x8 bushings doesnt exist ok I thing that 0.8mm is the problem in my situation and I have to find spacers for sure!
    maybe bushings from other company could be installed without this problem?
    Im waiting reply from Dvo but nothing yet....
  31. #6131
    Oct 2017
    (Sorry, saw your post first in the Topaz thread but this info is probably a bit more relevant here).
    It's certainly possible, though I have been using the 35.2mm hardware with no issues on the lower mount. It almost sounds like DVO's hardware might run on the narrower side, which might not jive well with some Riots? Universal Cycles actually has some 35.99mm hardware, if you can get it in Greece it might be a good option:
    https://www.universalcycles.com/shop...s.php?id=76427
  32. #6132
    Apr 2014
    Maybe I can find the bushings from Fox here!
    Its compatible 100% because Im no expert!
    In Europe sites I find the M8x35.56mm fron fox but this is alumium not plastic...
    Im waiting solution from DvO send me 2nd mail now after my findings....
  33. #6133
  34. #6134
    Not a role model
    Reputation: ninjichor's Avatar
    Jul 2018
    Pros:
    - CBF suspension, with published AS, AR, and leverage ratio
    - Nice CS/WB proportion in med
    - DHF and DHR2/Aggressor tires stock
    - Shipped in Evoc bike bag
    - Lifetime warranty and crash replacement policy
    Cons:
    - Not sure about clevis driven shocks, due to reports of damage to such shocks (I follow Vorsprung and he doesn't seem to like them, and Yeti claims that their mini clevis is the only one condoned by Fox)
    - I don't like actual seat angles being parallel with the head angle (~66d), no matter how steep the effective STA is
    - I don't like cables being routed under the BB
    - Starting at $2600 for frame, $5000 complete (SRAM spam)
    Questions:
    - Worry about conflict in names with Semenuk's Revel Co
    - Shorter links = better?
    - That CBF illustration showing the IC and CoC looks a little off...
    - Heat shrink on cables from factory?
    - Topaz shock option?
    Better wait for the real deal, IMO. Seems like function was compromised for form here.
    2015 Canfield Brothers Riot 29er FS-revel-rascal-29er-full-suspension-mountain-bike-canfield-suspension-7.jpg
    - Revel Rascal 29er 140F/130R
  35. #6135
    Oct 2015
    Pros- Canfield gets money from licensing out their suspention, which is one of the most efficient active suspension designs.
    Cons- doesn't have the whole package. Short chainstays and the 9er is less travel than the current Riot.
    I hope this company does well so Canfield gets paid. And Canfield still makes bikes.
  36. #6136
    Oct 2017
    Definitely an interesting bike (visually looks like a Canyon Spectral 29er), but it doesn't seem like much of a Riot replacement. Besides the points that Ninjichor stated, it also lacks Canfield's signature short chainstays, the Riot's steep STA, and Canfield's anodized links. That said, hopefully licensing out their suspension design will help keep Canfield afloat.
  37. #6137
    Gets a week's worth of hype for CBF hopefully. That's good!
    I bet it's a fun bike to ride.
  38. #6138
    Apr 2014
    Me racing in EnduroGreekSeries Round 1st Nafpaktos
  39. #6139
    Oct 2017
    I fitted up the 22.2mm hardware from DVO, but the play in the upper mount still remains. I measured the frame and both the set of 22.2mm DVO hardware and a set of 22mm DVO hardware:
    Frame upper mount - 22.2mm
    Shock eyelet with IGUS bushings and o-rings installed - 16.16mm
    22.2mm hardware pin - 22.2mm
    22.2mm hardware spacers - 2.7mm
    Total 21.56mm, .64mm too narrow.
    22mm hardware pin - 22mm
    22mm hardware spacers - 2.63mm
    Total 21.42mm, .58mm too narrow.
    It seems like either the hardware spacers are too narrow, the IGUS bushings are too narrow, or the actual shock eyelet is too narrow. I've tried multiple sets of DVO hardware with brand new IGUS bushings and have always experienced identical play. Here's a video I took with the 22.2mm hardware, showing the movement:
    https://imgur.com/a/tOsFBSQ
    The shock makes a creak/pop each time it slides. I have a feeling the hardware is the source of the creaking I've been hunting for a few months.
    I took this info back to DVO and they kind of brushed it off, saying everything was normal. This rather surprised and disappointed me, speaking that they previously treated the movement as a problem. As far as I can tell, there seems to be far too much space in the hardware.
    At this point it doesn't seem like DVO wants to do anything else, and I don't know exactly where to go from here. Speaking that the Topaz is the OEM shock on the Riot, has someone else had an issue similar to this and managed to fix it without swapping to a totally different shock?
    Thanks.
  40. #6140
    Mar 2015
    Might try offsetbushings.com. They make both standard and offset hardware, and they custom make each one for your frame/shock. Typically you just give them the frame and shock info but if you think something is out of spec on your Im sure theyd work off your measurements.
  41. #6141
    Mar 2011
    Are you sure about that?
    According to CB page, Riot has 22 mm upper mount.
    I have some issues with shock mount . In my case, shock slide on the both side with standard RockShox mounts and Monarch Plus RC3. I added some rubber and I am going to buy shims.
  42. #6142
    Jul 2017
    Quote Originally Posted by q232 View Post
    This is from my response that I recently posted in the "Riot - Shock Tuning for CBF" thread.
    "I measured the frame's front end shock mount with digital calipers and got 22.21mm, and the frame's rear I got 35.22mm. I was sent an incorrect 22.0mm kit for the front (measured 21.95mm), and a correct 35.2mm kit for the rear (measured 35.15mm).
    So, I just ordered the correct size 22.2mm front mount kit from Worldwide Cyclery, and now I can sleep better at night again.
    https://www.worldwidecyclery.com/pro...t-22-2mm-x-8mm"
    I received the 22.2mm kit and measured the axle at 22.17mm. It fit perfectly, as opposed to the original 22.0mm kit where I could see the front shock mounts flex inward a bit as I torqued down on the mounting bolt.
    I didn't record what the width of the spacers were for the 22.2mm kit, but only remember that they were the same width for the pair, and they were both slightly wider than the spacers from the 22.0mm kit. I did not measure the width of the installed IGUS bushing in the shock eyelet either.
  43. #6143
    Oct 2017
    Quote Originally Posted by mothertruckinsteve View Post
    Thanks a bunch for the recommendation, it sounds like exactly what I need.
    I'm positive that the width is 22.2mm, I measured it with a set of digital calipers. Strangely enough, the lower shock mount for me came out to 35.55mm, not the 36mm that Canfield lists.
    Thanks for the info, it sounds like the 22.2 Fox hardware works great as well. From now on I'll be sticking to either Fox hardware or the stuff out of Offsetbushings.
  44. #6144
    Jul 2017
    It looks like OffsetBushings is still using aluminum spacers too, like they did when I ordered actual "offset" bushings from them like 4 years ago for another bike.
    I currently have not experienced the side-to-side/horizontal play at the front-end of my DVO Topaz though (even with the incorrect 22.0mm upper/front-end assembly I replaced), but my Riot is new ​new and I've only ridden it properly only 3 times (because it's now/still snow-covered here).
    Also, I bet the subtle variability in the lower shock mount of the frame's rear triangle doesn't really matter because the whole assembly is just a bit springy there when not bolted together (my opinion, which stinks just as much as yours :P).
  45. #6145
    Apr 2014
    I bought the burgtec hardware for the rear one and the gap gone...
    I right after a few rides or a month I hope to last longer for the dvo's hardware....
    and I will order for the front now because I see better quality
    https://burgtec.co.uk/product/standard-shock-hardware/
    2015 Canfield Brothers Riot 29er FS-53685640_2250646345155967_1903665711885058048_n.jpg
    And now in the rear mount the coil is off after a few tights with not right bushings...I didnt expect those problems with this company...
    I put throw bolt with lock nut like ages before.....
    I sent mail yesterday to Canfieldbrothers....Im waiting nothing that sucks...
    Dvo sent me back and tell me that sent me when are in stock the new hardware ok Im waiting...
    2015 Canfield Brothers Riot 29er FS-53797755_3164141793602261_415877895110524928_n.jpg
    2015 Canfield Brothers Riot 29er FS-53595937_2235544433384625_6641623781699747840_n.jpg
  46. #6146
    Mar 2011
    I have a lot of bad words only. Why they wrote one spec, but frame mount has other.
    I will check my frame on weekend.
  47. #6147
    Jul 2017
    Curious, what does the nut and bolt do that the original bolt and frame threads can't achieve?
  48. #6148
    Apr 2014
    I will fix it with helicoil titanium and maybe the frame will crack not the coil...
    the bolt is good and coil aluminum low quality that happens there...anyway Im waiting from bros answer or price for the one triangle or rear triangle.... I dont care I want that bike to works great because Im happy....
  49. #6149
    Mar 2011
    Are they active? Still nothing new on them webpage
  50. #6150
    Apr 2014
    They wait new frames riot aluminium...
    yes I think
  51. #6151
    I hope they still make aluminum frames. Wonder why they havent. Would love to have a Jedi!
  52. #6152
    Apr 2014
    One year without biking a lot all bearings dry and stock two of them....this is my problem in the bushings
    Have to installed enduro max bo now because brothers cant..maybe the last time I buy from this company...
    Im really dissapointed and I cant imagine this problems in 2019...
    And I didnt ride a lot...I hope to fix my bike without any problems after that.... I upload photos bearings its the badest chinese ever...
  53. #6153
    Reputation: mayha's Avatar
    Mar 2012
    Interesting...3 full years of riding hard in all conditions and my bearings are pretty good still. May replace a couple soon.
  54. #6154
    Quote Originally Posted by mayha View Post
    When you have one user that constantly seems to be an outlier with issue you have to start to wonder if its the product or the user.
    OG Ripley v2
  55. #6155
    Jul 2017
    I can't say that anymore. I went for just one 3 hour ride with the correct size 22.2mm shock mount kit, and looked late in the ride to see how it was doing. There is a bit of that side-to-side play at the upper assembly happening for me now as well.
    I didn't see that with the undersized 22.0mm kit, so the problem is that the spacers supplied in the 22.2mm kit are too narrow!
    I'll probably order a standard kit from OffsetBushings later on.
  56. #6156
    Oct 2017
    It seems like DVO's spacers are straight up undersized. If you do pull the hardware, it would be great if you could measure the spacers. My 22.2 hardware spacers were 2.7mm. I dropped by a local DVO dealer and they recommended just cutting some small shims from a can to prevent the movement. I'll start with that, and later on get some offsetbushing hardware. Disappointing that the OEM shock on the Riot doesn't have well fitting OEM hardware.
  57. #6157
    Apr 2014
    all my bearings it wasn't greased and 1 was stack a lot
    4/8 has damage a lot because its dry from factory I think...
    one year for God's sake....
    2015 Canfield Brothers Riot 29er FS-54353460_2244694889152215_8146257147403960320_n.jpg
    2015 Canfield Brothers Riot 29er FS-53278984_270739777135413_8860113396700282880_n.jpg
    those bearings is garbage for sure IF you have it just change it
    maybe for wheels are ok but links no no
    here skf is good but is for wheels not open links for MTB in my wheels works veyr good 2 years now!
    enduro max bo its the best ones for sure...
  58. #6158
    Jun 2018
    My stock bearings had to be replaced this month, after just under a year. However the bearings themselves were still alright, but the wishbone developed play and Seans recommendation was to replace them. I rebuilt my linkage and repacked grease in the old ones probably twice over the last year. I swapped for fancy shmancy black oxide blah blah enduro max's and they're much better.
    Hoping they survive the CO dust and remaining winter muck longer than the last ones did.
    My frame was a NOS 2017 bought around April/May of last year and had the standard Enduro blue bearings in them. No complaints about them really other than the odd play but I attribute that more towards manufacturing tolerances in the suspension layout. Wish shims had been the response from CB! I'd much rather curse for an extra hour trying to get a second set of shims in place on the wishbone than have to drop $$$ for new bearings anytime some side to side wobble shows up.
  59. #6159
    Had a similar issue with the bottom link having play inside the front triangle. In my mind it was a tolerancing issue. I placed a thin .02" shim in between the outside of the frame and the pivot bolt head. This effectively shortened the shoulder length of the bolt and allowed for a bit of compression of the frame to take up the slop. This was only detectable with the bike taken apart under careful inspection of the front triangle and bottom link together.
    I should also note, that I only noticed this when I swapped my 2016 Large frame for a 2017 XL frame. The XL had a slight counterbore on the outside of the frame that allowed the pivot bolt to sit deeper, effectively lengthening the shoulder and forcing the bolt to bottom out before the play could be compressed out. The shim I added really just filled the counterbore depth and everything was happy after that.
  1. The NEW Canfield Brothers Nimble 9
    By KillingtonVT in forum 29er Bikes
    Last Post: 04-04-2015, 07:03 PM
  2. Some more Canfield Brothers DJ love....
    By rsullivan in forum Canfield
    Last Post: 11-04-2014, 10:53 AM
  3. 2015 Canfield Jedi or 2015 Trek Session 9.9 650b
    By metalMTB in forum Downhill - Freeride
    Last Post: 08-15-2014, 03:14 PM
  4. New Canfield Brothers Softgoods
    By KillingtonVT in forum Canfield
    Last Post: 10-09-2012, 08:32 PM
  5. Canfield Brothers Canada
    By atlanticrider in forum Canfield
    Last Post: 05-26-2011, 08:10 AM
Members who have read this thread: 209
