Removing fabric crease from heel cup?- Mtbr.com
Results 1 to 9 of 9
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    The upper part of the heel cup on one of my specialized pro shoes has developed a crease that causes the fabric of my socks to rub against my achilles tendon. it really hurts after about a hour of this. Ive thought about temporarily using tape and folding it over but i really need a permanent fix and dont want to pitch the shoes. Heres a pic...Thanks
    Attached Thumbnails Attached Thumbnails Removing fabric crease from heel cup?-shoe-crease-002.jpg
    That shoe looks fairly new. If it is, I would expect the Big S to warranty that defect. They don't like bad publicity, especially on forums like this.
    Reputation: sfgiantsfan's Avatar
    Dec 2010
    I can't tell you how to fix it but I think you have the right tools, magnifying glass, feather duster and a water bottle rack
    I'm sick of all the Irish stereotypes, as soon as I finish this beer I"m punching someone
    Reputation: GuruAtma's Avatar
    I wore a hole in the inner fabric of my shoe with a similar problem. I got a set of those stick-on pads from CVS. They're meant to go inside the heal cup. The work great. They should cover up your wrinkle too.
    CVS Heel Liners For All Shoes - CVS pharmacy
    功夫大师喜欢骑着他的自行车在山上。
    Sweater
    Reputation: Buzzaro's Avatar
    You could try heating it with a hair dryer to soften the material and work the crease out. Are they leather? If the hair dryer doesn't work you could try a cobbler or upholstery shop to see if you (or they) could try steam on them. Steam shrinks leather though...
    All out of S**** and down to my last F***
    Crazed Country Rebel
    Reputation: iheartbicycles's Avatar
    Quote Originally Posted by Buzzaro View Post
    I think that's what God invented cobblers for!
    Stupid, but sometimes witty. Occasionally brilliant. Slow and fat though.
    Mike Vandeman Sucks Dong
    Instead of going through the trouble of fixing it yourself and then possibly finding out that you cannot return it since you've modified it. I would just return it as a defective shoe and get a new pair.
    Best case: you get a new pair
    Worst case: You fail to repair it and you can't return them, because you did something with a hair dryer.
    It's about showing up.
    Reputation: Berkeley Mike's Avatar
    Return them. If that doesn't work then finding someone to rework the fabric is the next task. Few repair folk want this sort of work as it is not straightforward; it would be hand work.
    The original fabric was sewn a teensy bit torqued and this has shown as the interior pad has compressed with age and use. Simple smoothing won't take care of it.
    This is how would do it. I would cut the fabric at the outside seam where it meets the top of the exterior of the heel. It would be about a 1-1.5 inch horizontal cut. Pull the fabric snug and smooth. Then I would stitch it back together with strong thread, stitches about 1/16 apart and 1/16 inch into the softer fabric and the same onto the exterior fabric. I would then follow it with a larger stitch covering the first pass.
    I don't rattle.
    Once again, from the pic, those shoes look fairly new, ( unless you are unusually fastidious in the maintenance of your gear.....NTTAWWT) and being Spec Eds, they had to cost you. So, just like Berkeley Mike suggests, and I did too at the beginning of this thread, return them. the LAST thing a manufacturer of high-end mtb shoes would want are the explicit details of a defective product on a major mtb forum.
  1. Replies: 1
    Last Post: 11-19-2013, 11:35 AM
  2. What fabric should my kit be made of?
    By nixis in forum Beginner's Corner
    Last Post: 01-27-2013, 10:56 PM
  3. Waterproofing your fabric
    By Bill in Houston in forum Bikepacking and Bike Expedition
    Last Post: 04-07-2012, 10:50 PM
  4. crease in my Raleigh XXIX fork leg?
    By SteveF in forum 29er Bikes
    Last Post: 12-24-2011, 10:55 AM
  5. Removing stickers w/o removing rack paint?
    By jrm in forum Cars and Bike Racks
    Last Post: 05-20-2011, 08:25 AM
