Chris King Bottom Bracket Tool - anyone have one?- Mtbr.com
Results 1 to 9 of 9
    Does anyone have a Chris King Bottom Bracket Tool I can use? I'll pay you $10 to use it. I can go to the LBS to get it installed for free, but they have the Enduro ABI BB tool, which will definitely scratch the CK BB I just bought. I'm in Modesto, CA.
    "'I'm here to guard and protect your heart." (Kasey to Ali, The Bachelorette 2010)
    The CK BB uses the same tool as Shimano BBs which are readily available (e.g. Park BBT-19). I would recommend forking out just a few extra more $'s and make the investment if you can... you will definitely need to use it again and again.
    Quote Originally Posted by rsato1
    Do you know if the Park tool is made from aluminum or steel? If it's made from steel, it will definitely mar the CK BB. Trying to keep my BB looking pretty.
    Rubber side down
    I bought the tool and the greese injector for $70. Well worth the investment. I live in Tahoe City, sorry can't help.
    Jack Tupp
    Quote Originally Posted by TitusMotolite
    I used the park tool on 3 CK BB so far. No mars at all. You do have to make sure both the BB and tool are clean and grease free. You also have to make sure you have the tool on all the way at all times you are torquing it.
    So, CK bb tool is Al???? I wouldn't think that would be strong enough. Or, worse yet, the tool deforms before your part does. That makes the tool worthless or questionable for future use.
    Lead by my Lefty............... right down the trail, no brakes.
    Reputation: Trailseeker's Avatar
    Aug 2005
    I used the park tool my my KK bottom bracket and it made a few tiny marks in the slots. hardly noticeable, though. Oh well.
    Quote Originally Posted by ziscwg
    Ditto on the above--- no scratching issues on my CK BB. Make sure you keep one hand to apply lateral pressure to seat the tool firmly on the BB cups while installing/removing. The CK BB has rounded cups which makes the tool easier to slip if you're not careful. You could also try wrapping the BB cups with some masking tape to protect marring against the tool.
    Park Tool it is! I'll make sure I put masking tape on the BB to prevent any marks. I'll let you guys know how it goes once I get it installed.
    FYI, you can often get the compatible Shimano tool for $5-10 at a local shop. I paid $5 for mine & it didn't make any mark whatsoever on my King BB (no tape necessary).
