Bay Area Rockshox service expert?- Mtbr.com
Results 1 to 18 of 18
    Ride, Race, Live
    Reputation: Mick-e's Avatar
    Apr 2017
    I have a 2016 Rockshox Pike RCT3 non boost that needs the hands of an expert.
    This fork has been serviced and upgraded and should be as good as a new 2019 fork but to me doesnít feel correct.
    Iím looking for a shop that has deep experience servicing Rockshox forks that can help figure out whatís wrong.
    Looking for recommendations.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    The Bicycle Garage in Fremont is the guru for all things Rockshox. Itís worth the trip across the bay!
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    How about someone in the North Bay?
    I contacted Breenan Autosports in Benicia but they don't do Rockshok any more. I would like to get my same era RCT3's dampener rebuilt.
    J
    I highly recommend Tread in Campbell for suspension.
    NRP
    NRP is offline
    Sep 2015
    Not North Bay, but check out Full Flow Suspension in Auburn. I think you can ship your stuff to him.
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    Ride, Race, Live
    Apr 2017
    Thanks.
    Iím in Oakland so Fremont is not so bad
    Mar 2018
    Nothing in the north bay... mountain biking died there.
    Quote Originally Posted by NRP View Post
    This. Mike is good.
    Brennan Autosport - Northern CA Performance Damper Tuning & Service Center
    Brennan is in Benicia/Vallejo area. He'll do service and sales of high end after market suspension.
    Reputation: JimF777's Avatar
    Sep 2018
    Quote Originally Posted by Mick-e View Post
    Breakaway Bikes in Santa Rosa (that's definitely north bay). I know they do shocks, so I assume forks as well.
    Quote Originally Posted by the.vault View Post
    I contacted them and they said they no longer do Rockshox.
    Jeff
    Mar 2016
    Chris at Frame Up Bikes in Walnut Creek does Rockshox & Fox suspensions. Give him a call. He has done great work for me.
    Catfish ...
    MK_
    MK_ is offline
    carpe maŮana
    Reputation: MK_'s Avatar
    What's the issue?
    Maybe it's solvable by you?
    _MK
    "The things you get fired for when youíre young are the same things you get Lifetime Achievements for when youíre old."
    Reputation: redmr2_man's Avatar
    Quote Originally Posted by MK_ View Post
    What's the issue?
    _MK
    This. They're usually super easy, what's your issue?
    Quote Originally Posted by redmr2_man View Post
    I guess because it is 5 years old now. I have done the oil changes and seals and they are quite easy. I am just thinking it would be good at this point to rebuild the dampener. That is more involved and i am not sure I want to take that on or not.
    suspension often gets lousy and doesn't always just die. I have had rebuilds in the past come back and it was like a new bike. The fork still "works" but I am thinking it isn't as good as it used to be.
    Thoughts?
    Jeff
    MK_
    MK_ is offline
    carpe maŮana
    Quote Originally Posted by jeph View Post
    Thoughts?
    Jeff
    The OP says it has been serviced and upgraded so I don't think he's having an issue with the damper needing service?
    Upgraded could mean a new Charger Damper (2.0 or 2.1) or the new air piston with aluminum sealhead; or both.
    Curious what the OP is feeling that is triggering not right feeling.
    _MK
    Ride, Race, Live
    Apr 2017
    _MK
    This
    Both
    2 things
    In order to get to the desired sag % I have to run really low air pressure. Something like 50 when it should be loser to 80
    Thatís a sign something isnít right.
    Also the initial stroke. That break away pressure when youíve applied enough force to overcome the stiction is way too much.
    As a concept imagine standing over your bike and leaning forward. When you lean on the handle bars at first the fork doesnít move, but you havenít put much weight on it as you lean a little further it breaks the stiction and squishís in a soft plush manner.
    Mine kind of holds on then pops.
    It feels wrong.
    Everythingís new.
    Somethings not right.
    I want a professional to feel it and help guide the next step
    MK_
    MK_ is offline
    carpe maŮana
    Sounds like an issue my wife's Pike developed. Air escaping the positive chamber and going into the lower leg.
    Is your fork also topping out harshly?
    If you're handy, try this, flip your bike upside down, undo the footnut on the air spring side then tap the shaft into the lower leg; you'll probably hear a hiss of air escaping; that's the air that's in the lower leg. If you attach and tighten the footnut, I bet your fork will feel normal after all the pressure is released.
    To fix this, you'll need to pull the lowers then release air from the air spring. Then remove the C-clip and pull out the air shaft and the seal head. You may need to replace the o-ring but if it's been serviced, it's possible the slick honey wasn't applied well. Apply liberal Slick Honey to the o-ring and then re-assemble. Should be good as new.
    _MK
  1. Replies: 12
    Last Post: 11-01-2011, 03:14 PM
  2. Shimano Custom Fit Service in Bay Area?
    By hairylegs in forum California - Norcal
    Last Post: 07-21-2011, 01:32 PM
  3. Replies: 17
    Last Post: 01-18-2008, 02:41 AM
  4. Crank Brothers dealer in the bay area (south bay)?
    By kster in forum California - Norcal
    Last Post: 12-21-2007, 12:11 PM
  5. Help me find a good Rockshox service shop in the Bay Area
    By justflow in forum Downhill - Freeride
    Last Post: 05-13-2007, 01:08 AM
Members who have read this thread: 136
