XX Brake lever clicks out away from handlebar- Mtbr.com
Results 1 to 7 of 7
    My XX brake lever (front) clicks outward away from the handlebar, if I pull it that way. Is this supposed to happen? If not, any idea what could be causing this? I am new to hydaulic brakes, so sorry if this is a dumb question.
    It is supposed to do that. My XX brakes do the same thing.
    2011 S-Works Epic 29er
    Reputation: DavidR1's Avatar
    Gives you access to one of the adjustment bolts.
    CyclingCentralVa.org
    Any idea why?
    Never enough time to ride
    Reputation: squish's Avatar
    It does that so it won't pull on the piston in a crash. The old Juicy, and Formula's do this as well. Freaked my out with my J7's when it happened the first time, but then it popped back in and all was ok.
    happy trails...
    squish
    Get out and ride!
    Feb 2010
    When you change wheels / fix a flat etc. you pull the lever out to "lock" it so you can't accidentally push the pads together and make it a pain to get the wheel back in. Its a great feature if you transport your bike with wheel(s) off or if you don't want someone squeezing the brakes while you're doing something else.
    Legend
    That feature is there to scare the crap out of you when you try to grab your brake lever but accidentally hit the back of the handle in the "reach" phase. Try to stop, no lever. I resorted to putting little wires around my brakes for a while to disable this "feature". I eventually disabled it somehow; slipping my mind on how I did it.
