XTR hubs/rotors with other disc calipers?- Mtbr.com
Results 1 to 3 of 3
    Not just famous; infamous
    Reputation: coolhandluchs's Avatar
    Has anyone tried using the new center lock XTR hubs/rotors with other company's calipers? I'm thinking about using the XTR hubs with the Hope Mini Mono or Avid Juicy specifically.
    Just wondering about compatitbility issues. I'm guessing that rotor thickness and diameter are the most important, but there's also the frame/caliper spacing and hub/rotor spacing to think about.
    Anyway, just wondering if anyone has experience with this kinda swap.
    the Truth will set u free
    Reputation: AndyH's Avatar
    Quote Originally Posted by coolhandluchs
    The main issue to be concerned with is the narrower brake "track" of the XT and XTR rotors compared to rotors from other manufacturers. If you use a caliper/pad combo that requires a wider brake track but use the XTR rotors, the brake pad may hang over the outer edge of the rotor and also contact more of the "spokes" of the rotor, thus reducing the potential braking power. Some folks have done it however, I'd suggest doing some searches over on the oldf Brake Time forum to see if you can locate the posts. Good luck!
    2001 Ellsworth Truth
    Some combos do work quite well........
    I know it to be fact that the XTR rotors work with Hayes brakes on Fox Forx and Blur frames.
    And, Crossmax SL Discs work with Hayes rotors and XTR calipers on Fox Forx and Blur frames.
  1. Need disc brake adapter 74mm to 51mm
    By DIYguy in forum Brake Time
    Last Post: 01-26-2004, 10:15 AM
  2. Debating which XC disc wheelset - opinions?
    By Spookykinkajou in forum General Discussion
    Last Post: 01-23-2004, 03:43 PM
  3. American Classic/WTB disc hubs
    By GrantB in forum Wheels and Tires
    Last Post: 01-19-2004, 08:44 AM
  4. For those who have warrantied their XTR disc brakes....
    By mike@one-speed.com in forum Brake Time
    Last Post: 01-17-2004, 09:35 AM
