Results 1 to 3 of 3
    xtr compatible brake levers
    I've got an XTR 975 front brake caliper and I'm wondering if i can use xt levers or what other levers would be compatible
    i'm putting it on a rigid fork single speed that i'm building up and could use some advice before spending money on a lever that won't work
    Have you checked the shimano website!?
    They have a technical side to thier products to let you know what/which ones are compatible with what products
    2008 Specialized Stumpjumper Expert Carbon
    • OEM Spec
    You can mix and match Shimano levers and calipers.
  1. Twist shifter compatible v-brake levers
    By Bokchoicowboy in forum Brake Time
    Last Post: 10-09-2008, 05:59 AM
  2. Compatible V-brake Levers?
    By RockiMtn in forum Brake Time
    Last Post: 06-30-2008, 07:11 AM
  3. flat bar / canti compatible brake levers ?
    By the pope in forum Singlespeed
    Last Post: 05-15-2008, 10:39 PM
  4. Shimano Compatible Disc Brake Levers?
    By JKP in forum Brake Time
    Last Post: 08-02-2005, 10:27 AM
  5. Are XTR M900 levers V-brake compatible?
    By dgdixon in forum Brake Time
    Last Post: 02-14-2004, 03:34 PM
