XTR brakes, what do I need to make them work- Mtbr.com
Results 1 to 3 of 3
    MC Hammer
    Reputation: XC Dawg's Avatar
    'm contemplating XTR disks, I don't have an XTR wheelset and have a few questions
    First off, are they worth the $$$?
    Secondly, I read that the rotors do not fit non-shimano hubs, does this mean I can purchase a regular rotor and "adapt" them to it?
    Will I need any additional pieces of hardware to make this conversion?
    Can I use regular Levers with this or do I have to go with XTRs?
    Meh.
    Reputation: XSL_WiLL's Avatar
    Centerlock rotors only fit Centerlock hubs (other companies use centerlock too). You can adapter standard centerlock hubs to use 6 bolt IS but not the other way around.
    They won't be XTR rotors, but Shimano sells 6 bolt IS rotors as well.
    You can use any Shimano hydraulic lever.
    Vaginatarian
    Quote Originally Posted by XC Dawg
    what do you have now?
    unless you're a weight weenie or have lots of $ they are prob. overkill, the new 08 xt is a better deal
    you should use shimano rotors and levers, they dont have to be xtr or centerlock, the caliper dont care
