XTR brakes need bleed every ride- Mtbr.com
Results 1 to 12 of 12
    May 2010
    I've got a set of XTR brakes that need bleeding every ride. They get mushy and I get air out from the lever every time. I don't see any leakage anywhere. Is there a bladder or something in the lever body that probly has a pin hole? New lever or lever & caliper?
    since 4/10/2009
    Reputation: Harold's Avatar
    how old are they? XTR bits have a 3yr warranty, fwiw.
    May 2010
    More than 3, about 5yr
    Short-Change-Hero
    Reputation: gregnash's Avatar
    Lever could be failing, caliper could be failing, line(s) could have pin holes. When was last time they had a full bleed/flush?
    May 2010
    Quote Originally Posted by gregnash View Post
    A few months.
    Sent from my SM-G970U using Tapatalk
    Short-Change-Hero
    Quote Originally Posted by brado View Post
    A few months.
    So a few months ago you did a complete fluid change and this is when the issue started? Using Shimano fluid or off-brand? Have read that the brand does tend to cause issue if not Shimano branded stuff.
    May 2010
    It's been an issue for a long time, before the fluid change. Shimano oil.
    Sep 2014
    Does the piston area where the lever actuates have oil build up?
    Both my XTRs had a slow leak from there and I needed to burp air from the lever every few weeks. Eventually the seals in one of the levers just failed and the lever needed to be replaced. My friend's Shimano levers are doing the same thing and he needs to bleed them constantly.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Shimano are throw-away-brakes. Your seals sound shot. The design of the brakes accelerates wear on these and shimano doesn't sell seal-kits. Shimano doesn't sell seal kits because F-you riders. Welcome to brakes in 2019.
    Trail Gnome
    Reputation: Dark Meat's Avatar
    Jan 2011
    ^^^Jayem speaks the truth.
    WillWorkForTrail
    Jun 2012
    Time for some Maguras I guess.
    Just a flesh wound
    Reputation: Prophet Julio's Avatar
    I have had great luck with Shimano brakes. The fluid is not DOT, so it does not absorb water. But a full bleed every thousand miles can't hurt. Air the way you describe is from a leak. Might be a seal. Might be a leak at the reservoir.
    My name is Chris and I ride a Ripmo now.
  1. Replies: 9
    Last Post: 06-05-2019, 06:26 AM
  2. Replies: 105
    Last Post: 05-12-2019, 06:43 PM
  3. Replies: 1
    Last Post: 11-22-2013, 12:23 PM
  4. Replies: 9
    Last Post: 07-31-2013, 06:55 PM
  5. why do I need to bleed my hayes every freaking week?
    By snipes287 in forum Brake Time
    Last Post: 03-10-2004, 06:22 PM
Members who have read this thread: 147
