XTR 970 IS calipers only?- Mtbr.com
    Dec 2009
    Guys does XTR 970 calipers come only in IS (adapters built in the calipers)? Wanted to switch my calipers for XTR but my fork is a post mount. All sets I found on ebay are IS, is their a adapter or anything I can do?
    Thanks.
    R.G.Specht
    Reputation: Nuts's Avatar
    Quote Originally Posted by mtbiker3995
    Thanks.
    R.G.Specht
    You should be able to mount the calipers directly to the PM on your fork. You may need spacers and longer mounting bolts if running a larger rotor.
    Nov 2008
    M975 post mount.
    Thanks.
    R.G.Specht
    There are two IS and one post mount for the 970 series. (M975)
    You may need to call or visit your LBS.
    Steven
    ups and downs
    You can get all versions of them here
    http://www.universalcycles.com/shopp...97&category=30
