XT brake lever won't return.- Mtbr.com
    Reputation: KRob's Avatar
    After a crash on some rocks my rear brake lever on my XT hydraulic brakes won't return fully after compressing it.
    I checked the lever and the lever housing but it doesn't show any sign of being bent or damaged.
    I bled it knowing it was needing that anyway and thinking maybe there wasn't enough fluid pressure in the system to push it back out. That helped solve the problem for the most part (it still drug a bit about halfway out before returning) but by the end of the first ride it was back to sticking.
    So I suspect there is something damaged or worn. What can I do to further investigate and fix this problem?
    Isaiah 58:14
    www.stuckinthespokes.com
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Seeing that you've checked the brake lever and perhaps have ensured that the master cylinder piston is returning and itís not the problem...my initial response would be to remove the rear wheel and check to confirm that the brake puck is retracting back into the caliper.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    West Chester, PA
    Is your shifter pressing against the bottom of the lever pivot pin ?
    See my reply at the end of this thread -
    http://forums.mtbr.com/brake-time/xt...ow-861822.html
    Quote Originally Posted by 92gli View Post
    Actually this was it. I noticed that they were pressing against each other fairly tight so I loosened the shifter and rotated it away from the brake lever housing and the problem is (mostly) solved. It does return now but there's still a bit of a hitch in the return stroke about half way.
    Isaiah 58:14
  1. SRAM xo brake lever - sluggish return
    By noonievut in forum Brake Time
    Last Post: 03-16-2014, 03:34 AM
  2. avid brake lever slow return rectified!
    By eric22 in forum Brake Time
    Last Post: 05-10-2013, 10:27 AM
  3. XT slow lever return
    By skywalker268 in forum Brake Time
    Last Post: 02-26-2012, 01:54 PM
  4. Replies: 1
    Last Post: 10-27-2011, 04:51 PM
  5. Shimano XTR Disc - Lever Does Not Return
    By harshcore in forum Brake Time
    Last Post: 03-31-2011, 12:28 PM
