Where to find cable stop sleeves for hydraulic hoses?- Mtbr.com
    Reputation: nanda's Avatar
    I am helping a friend overhaul his Kona - the frame is a couple years old and the top tube of the bike has what are essentially drilled out cable stops with big gaps that the rear brake's hydraulic hose runs through. The gaps in the stops are bigger than the hose, so to snug things up there are a couple flexible plastic sleeves (with a shoulder on one end) that wrap around the hose and push into the cable stop. Does anyone know where I might get a couple of these plastic sleeves? I don't even know what they are properly called...
    aka übermensch
    Reputation: Triple T's Avatar
    08 Ibis Mojo SL
    09 Ibis Tranny SingleSpeed
    Exactly - thank-you!
    Feb 2007
    LBS. It's my first stop for little things like that. They may have excess parts that they may part with for free. I've scored many freebies from LBS.
