    Reputation: misctwo's Avatar
    What size rotor to use with Formula K24 and RS Totem?
    i have a set of 160mm rotors set up with K24's. the Totems have direct post mounts for "8" rotors. I've heard that 203mm rotors work...
    will 200mm rotors also work? i'm guessing that they would....just wanted to make sure...
    greg@formulabrakeusa.com
    Guest
    We make a 203mm rotor specifically for that setup. 200mm will be slightly undersized.
    Cheers,
    Greg
    Quote Originally Posted by greg@formulabrakeusa.com
    Cheers,
    Greg
    eggcellent. Thank you greg.
    Cheers,
    Greg
