What can i use instead of brake pads?- Mtbr.com
Results 1 to 52 of 52
    look 986
    Dec 2009
    To keep running costs down is there an available alternative to brake pads?
    Thanks in advance for your suggestion
    Quality is paramount, weight is a consequence.
    Quote Originally Posted by demc1982
    I've heard the Fred Flintstone stop is pretty effective.
    look 986
    Dec 2009
    I was advised to try bacon fat but in practice this was not a good idea. I have a good feeling about using bran flakes though.
    Reputation: donmeredith74's Avatar
    Don't worry so much. Save weight and remove the brakes. Most riders use them when it isn't necessary anyway. When you're going too fast you'll crash resulting in a slower speed. Get up, rinse, repeat.
    look 986
    Dec 2009
    Yes! Or i could just dunk my nuts between top of rear wheel and frame.
    bt
    bt is offline
    Nov 2007
    pour your bong water on them for longer lasting results.
    Reputation: mtbnozpikr's Avatar
    Chances are if you drop the brake pads for something else you will end up paying more for other things such as medical bills. I hope you're not serious about this whole alternative to brake pads thing.
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
    You could use your girlfriends box, just have her sit on the handle bars and when you wanna stop have her squat and clinch.
    Former Bike Wrench
    No brake pads needed
    T.W.O.
    Reputation: mimi1885's Avatar
    +1 on Fred Flintstone technique. Works really well and cheap too.
    Reputation: 006_007's Avatar
    For maximum stopping power a stick through the spokes will stop the wheel instantly.
    IdontShootPeopleAnyMore
    Reputation: DriveByBikeShooting's Avatar
    for v brakes you can slice the calf off a barbie doll and screw it on a worn out pad...
    for disc brakes take a piece of shingle off your roof and jam it in their... that works pretty good after broken in...
    What mountain bike forum do pirates use? .....
    MTB-arrrrrrrrrrrrrrr
    Dirt Deviant
    Reputation: savagemann's Avatar
    Just convert your bike into a fixie!!!!
    All the cool kids in girl pants are doing it.
    Look, whatever happens, don't fight the mountain.
    Reputation: lexvil's Avatar
    Yes but I heard your face does not work as well as brake pads.
    Pimpmobile
    Put your foot between the front tire and fork crown....
    Used this method a lot in the old BMX days.
    Or, you can just use the trees to slow you down, it works for me when I ski!
    "Fear not the ob-stackles in your path"
    Linoleum Knife
    Reputation: forkboy's Avatar
    Quote Originally Posted by meloh1
    I used this the other week after a poorly done brake bleed. It got old after a few miles...
    Probaby costs more in shoe wear than new pads as well.
    Nice answers guys, however, I think this is a good question.
    There must be some substitute that could be used in a pinch.
    I'm sure someone has tried something that works OK, so let's hear it!!
    My first thought was hardwood. A piece of OAK would smoke and not last long and I doubt it would catch fire. Heck.... the San Francisco trolley cars all use wood for brake pads and those are some big hills.
    Reputation: sanjuro's Avatar
    Sep 2004
    maxi pads?
    Brake pads are the parts that wear out. So, the brake pads are the parts you need to replace. Do you drive, own a car? These also have brake pads that have to be replaced when worn. Buy several sets of cheapie pads (BBB, Kool Stop, etc) change em when worn. I get a year on the brake pads on my bike. $20 a year won't hurt you. Buy less dope for 1 month, put the money into an intrest bearing account. You will have lots of money to spend on brake pads.
    Reputation: vk45de's Avatar
    how many joints have you had before starting this thread? if you're looking for economy, i suggest rehab
    ipad?
    Rollin 29s
    Reputation: isleblue65's Avatar
    I suggest using a small piece of dried out power bar, which has the added benefit of providing much needed protein when it stops working and you find yourself off the edge of a ravine with 2 broken legs in a remote area.
    I've been saved twice by this method.
    Whoever invented the bicycle deserves the thanks of humanity.
    - Lord Charles Beresford
    Linoleum Knife
    Quote Originally Posted by egebhardt
    Would you replace your car's brake pads with a piece of Oak and then go drive on the freeway?
    Reputation: Vmax911's Avatar
    I'm thinking toast. If you need more braking power, use burnt toast. Do NOT use buttered toast!
    locked - time out
    I use non-lubricated rubbers.
    Used, of course.
    look 986
    Dec 2009
    Baked coconut shell!?
    local jackass
    Reputation: biggoofy1's Avatar
    deez nutz
    His
    2010 FSR XC
    2010 ALLEZ
    Hers
    2012 Myka 29'r
    2009 Cannondale Synapse 5
    Down East Cyclists
    Break one of your mom's favorite ceramic vases and then use the fragments...make sure its genuine china and not some cheap knock-off.........
    No longer a hardtailkid.
    Reputation: hardtailkid's Avatar
    If you wanna stop that bad, jump.
    Quote Originally Posted by anthonys
    Its still just the push of a button away...
    I am no longer a hardtailkid. 2012 Trek Remedy 9!
    Oct 2007
    A parachute?
    An anchor? Just carry it around and when you want to stop just drop it.
    2015 Niner Jet 9 Carbon
    2014 Focus Raven 27R
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
    Quote Originally Posted by forkboy
    If it tested OK, sure.
    San Francisco trolley cars use wood.
    Reputation: onegymrat's Avatar
    I think the sheer volume of absurd responses is only overshadowed by the silliness of the question. To the OP, I don't think it's a good idea to be inventive with something as vital as your brakes. Cutting cost makes sense when you shop around online to see who has the best sale, or if a "no-name brand" is a good substitute for original manufacturer...but not when one tries to replace brake pads with some homemade invention.
    Oh Oh Oh I know I know
    148.3 grit sandpaper.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Coaster brakes FTW
    look 986
    Dec 2009
    Quote Originally Posted by ljsmith
    A parachute?
    Brilliant. This would double up as good resistance training too! Win win springs to mind
    look 986
    Dec 2009
    How about moulding some dried weetabix into the shape of pads? Could be used as a good source of carbs when they need replacing- environmentally friendly too!
    look 986
    Dec 2009
    Quote Originally Posted by onegymrat
    Lots of people seem to disagree...... Brakes and slowing down are over rated
    i could be way off but maybe this guy is saying if a brake pad set just disintegrates in the woods, is there anything too pull a macguyver trick for a short brake save too make it home. i could be wrong but this has never happened too me so i have no suggestions. kinda of a bad move i would think cause anything you JAM in between your rotor would probably just jam into the holes in your rotor and be of no use my suggestion if this happens take it slow till you get back or walk. yea i too think DAMN what a dumb question, but well there are a lot of dumb humans on this planet! this one is pretty much lacking all common sense, sorry ,no insult intended but come on think about what your asking here! LOL
    Quote Originally Posted by pode
    Been there done that. Pad peeled off both sides of the front brake....
    Just kept riding the steel on steel slowed me down okay....
    Got a new set of pads, sanded the rotor and good to go...
    yea im sure it had happened before just not too me.LOL
    look 986
    Dec 2009
    Quote Originally Posted by jeffscott
    LOL!
    look 986
    Dec 2009
    Or maybe your the dumb one for actually thinking this is a serious thread. Most people could work this out just from reading the replies, i mean an anchor and a parachute? come on! After spending thousands on a bike i ain't gonna skrimp on a 10 set of pads. Grow a sense of humour dude
    that is awsome your sooo cool. i have a sense of humor but ya know what, there are some real dumb people out there so just too be sure you were not trying something like this is the reason for a semi logical response before i called you dumb,I DONT KNOW YOU!.starting a dumb ass thread then calling someone dumb for posting realistically just in case you were as dumb as the post implied is just ignorant, like i said your so cool man . ride hard
    WE DONT KNOW THAT THIS THREAD IS A JOKE!!!!!!! ITS INCREDIBLY HARD TO CONVEY SARCASM OVER THE INTERNET!
    To the people, such as myself, who posted a sarastic response: we just figured that if you are dumb enough to post this, asking a serious question, you deserve some sarcastic responses.
    And to those who posted a serious response: they figured you were serious. Again, THEY DON'T KNOW IF YOU ARE SERIOUS!!!!! They just figured, that in case you are serious, you should get some kind of advice.
    None of us knew that you spent so much money on your bike, so don't hold that against ANYONE here. And don't be an arse biscuit to the people who answered with a serious response, because it's your fault for not saying something in your first post like "Post a funny response and no, I'm not seriously asking this question."
    Now go ride your five thousand dollar bike, and don't forget to pack a ShamWow in case it gets dirty.
    K? thx bai
    How about another rider in front of you? And on public roads you could use cars. Oncomming traffic should work a treat as a really quick brake.
    look 986
    Dec 2009
    LOL. This could only upset some one, in this way, of an older generation. Any one else just wouldn't have replied.
    Quote Originally Posted by hardtailkid
    K? thx bai
    it's called trolling chillax
    look 986
    Dec 2009
    Quote Originally Posted by vk45de
    None, i am a dedicated athlete
    look 986
    Dec 2009
    hmm
    Reputation: Miami_Son's Avatar
    May 2010
    I hope you stop...procreating.
    Dammit guys stop feeding the trolls.
    Eddy current brakes!
