Water in hydros...- Mtbr.com
    Reputation: CanadianPreston's Avatar
    New question here. Water in hydros...
    I was washing my bike with a very powerful hose......
    I'm sure that water has penetrated either my lever or the pistons because the rear brake lever now retracts a lot slower. I havent had a chance to ride the bike since.
    Will this water burn off/evaporate after a ride?
    Meh.
    Reputation: XSL_WiLL's Avatar
    DOT fluid is hygroscopic. It would have absorbed the moisture. This would result in a lower boiling point. I high doubt that you will be able to vaporize the DOT fluid. In addition, your brake is a sealed system. I don't think water could have forced it's way through the hose or caliper unless something was already damaged.
    Reputation: wyrm's Avatar
    Washing some brakes off leaves the piston very dry. The surface then has friction points and may lock one piston off.
    Easy fix: Remove wheel, remove brk pads, retract pistons (reset or push them in), apply a lite teflon lube to pistons, let sit....... pump levers and reset pads, wipe clean of excess lube.
    Wyrm
    Bikeless Rider
    Quote Originally Posted by wyrm
    Wyrm
    thanks i may try that
