Results 1 to 2 of 2
    Reputation: MyDogLou's Avatar
    Jun 2005
    V-Brake installation problem/question
    Iím attempting to install a set of Tektro v-brakes on a set of Marzocchi MZ Race forks. The problem that Iím having is the brake arm doesnít go entirely down the brake post; therefore, the spring-base pin doesnít go into the pivot boss.
    Are there different size brake pivot bosses? I got the bosses from the LBS.
    Am I just doing something incorrectly?
    The rear brake went on without a hitch.
    Note: The bike had disc brakes originally, in the process of a SS conversion.
    Thanks in advance for any information.
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Yes there is i had that same problem about 6 years ago. Your LBS should be able to hook you up.
    http://www.bikeparts.com/search_resu...869_889%2E5075
