Upgrading avid juicy for Avid Elixir 9 Trail brakes, can I use existing adapter?- Mtbr.com
Results 1 to 8 of 8
    Reputation: bertrenolds's Avatar
    Jul 2013
    I have avid juicy ultimates and am finally done with them so I picked up a new set of avid elixir 9 trail brakes front and rear, can I use the mounting brackets I have from my juicy ultimates for 185mm and 203mm rotors for my new calipers? I am fine mounting CPS with the washers on both sides and I am reusing my g3 rotors.
    Jul 2013
    In case anyone is wondering in the future, I called SRAM and as long as I continue to use my old rotor and don't change the size my existing mounting brackets from my old juicys will work just fine with their new elixer trail 9 calipers.
    B A N N E D
    Elixir Trail 9 brakes do not use CPS washers on the underside of them.
    CPS washers on the underside of them will make the brake pads overhang the rotors by about 5mm.
    Juicy's are a CPS caliper and need the extra packing underneath them that CPS washers give.
    Trail brakes are standard calipers like most non Avid brakes and do not use CPS washers.
    https://www.sram.com/sites/default/f...r_mounting.pdf
    Jul 2013
    You positive about that? It looks like they can be mounted either way but if you do not use washers underneath you need to have a special tool to do something to them. It says in the link you posted that I have already looked at the CPS washers are needed between the caliper and mount if you choose to go CPS style. Even the CPS mounting diagrams on page 2 show washers on both sides. I know its confusing, shit I'm still a little confused but it shows CPS mounting with washers on both sides unless you are mounting standard. Unless I have to mount standard for a 203mm rotor? This diagram and table from the link is confusing as hell! So at the least I put it together and check my caliper clearance and remove the lower washers if need be. Does anyone understand this link? https://www.sram.com/sites/default/f...r_mounting.pdf
    B A N N E D
    Quote Originally Posted by bertrenolds View Post
    Yes, I'm absolutely positive.
    No they can't be mounted either way and there is no special tool.
    No it doesn't, CPS isn't a choice, you either have CPS calipers or you have standard calipers, you do not have CPS calipers so you do not use CPS washers.
    That's because CPS calipers need the CPS washers, you do not have CPS calipers so you do not use CPS washers.
    CPS calipers need the CPS washers underneath them and standard calipers do not use CPS washers underneath them.
    You will need to remove the CPS washers from underneath your Trail 9 calipers.
    Yes, it shows mounting for CPS calipers and standard (non CPS) calipers.
    You are using the old 203mm & 185mm rotors and adapters, you need to mount your new calipers in the old 203mm & 185mm adapters the same way a standard caliper is mounted on the new 200mm & 180mm adapters.
    Post to IS adapter with no CPS washers:
    Upgrading avid juicy for Avid Elixir 9 Trail brakes, can I use existing adapter?-1332329799287-1j8wp9e5tp6sb-700-80.jpg
    Post to Post adapter with no CPS washers:
    Upgrading avid juicy for Avid Elixir 9 Trail brakes, can I use existing adapter?-enduro-longterm-test-2014-rose-granite-chief-6.jpg
    What happens when you use CPS washers under a caliper when you are not supposed to use them.
    Upgrading avid juicy for Avid Elixir 9 Trail brakes, can I use existing adapter?-831692d1379103670-shimano-xt-brake-pad-wear-issue-img_7701_small.jpg
    Pads that overhang rotors can eventually lead to brake failure if the unworn parts of the two pads push against each other.
    Jul 2013
    You are absolutely correct, thanks! Just realized that the trail calipers are offset and are standard. So it looks like I just direct mount both of them. I am wondering how you adjust or center the caliper then? I am use to undoing the bolts, pulling the trigger and centering the caliper and tightening the bolts, is it still the same? Your awesome cooba, thanks for clearing this up for me. Sorry I did not believe you.
    B A N N E D
    Have the bolts just loose enough that the caliper can move on the adapter, squeeze the brake lever and wrap a rubber band around it to keep it pressed, tighten the bolts in small increments and alternate between the bolts, remove rubber band when the bolts are properly tightened.
    You could also center the caliper by sight.
    The CPS washers on your Juicy's would allow you to attach the brake on a slight angle if the fork/frame brake mounts were out of alignment.
    Jul 2013
    I got them installed, bleed 2 times, and all set up and they are so much better then my old juicy ultimate brakes.
    Cobba, thanks again for the help.
    Now if only my matchmaker x mounting brackets were bigger to fit my handlebars.
  1. Replies: 8
    Last Post: 09-13-2014, 04:01 AM
  2. Disc brake adapter for Avid Juicy 5
    By DragonMTB in forum All Mountain
    Last Post: 01-21-2013, 09:20 PM
  3. Avid Elixir/Juicy lever sticky
    By ridonkulus in forum Brake Time
    Last Post: 07-16-2012, 07:45 AM
  4. Massive Warrantys On Avid Juicy/Elixir Brakes
    By ae111black in forum Brake Time
    Last Post: 11-14-2011, 05:59 PM
  5. Avid elixir 3 vs juicy 3
    By HX520W in forum Brake Time
    Last Post: 03-05-2011, 04:16 PM
