Upgrading 2019 Norco Sight C1 From 180mm Rotors to 203mm- Mtbr.com
Results 1 to 2 of 2
    May 2020
    Hey all!
    I have a 2019 norco sight c1 with 180mm rotors front and back.
    Upfront on the fox 36 the brake caliper mounts directly to the fork. In the back there is already an adapter/spacer.
    What adapters / bits do I need to get so that 203mm rotors will fit properly? Thank you!
    BONUS
    Thoughts on tweaking 150mm of travel to 170mm with the fox 36 fork?
    B A N N E D
    Without knowing what adapter is on the rear, you should be able to work out what you need from the following.
    20mm adapter / 160 to 180mm & 180 to 200mm = Shimano SM-MA-F180P/P2 adapter
    23mm adapter / 180 to 203mm = Shimano SM-MA-F203P/PM adapter
    43mm adapter / 160 to 203mm = Shimano SM-MA-F203P/P adapter
    40mm adapter / 160 to 200mm = SRAM 40mm POST adapter
    Shimano adapters can be used with other brands like SRAM.
    180 to 203mm installation instructions: https://si.shimano.com/#/en/SI/0146A
    180 to 200mm installation instructions: https://si.shimano.com/#/en/SI/8170A
  1. What Rear Shock for Norco Sight C1 29er?
    By sfmtber in forum Norco
    Last Post: 04-15-2019, 11:09 PM
  2. Rotors, Rotors, Rotors, Rotors!
    By Putt4Dough in forum 29er Components
    Last Post: 04-03-2013, 06:47 AM
  3. Replies: 4
    Last Post: 01-18-2006, 07:41 PM
  4. Replies: 0
    Last Post: 01-18-2006, 06:14 PM
  5. Replies: 0
    Last Post: 01-06-2005, 01:10 AM
Members who have read this thread: 8
