    Lougrandview
    Are there rotor upgrades for Avid Juicy 7's?
    I need to get new rotors. I can't upgrade the brakes at this point but was curious if I could upgrade the rotors. I'm running the stock clean sweeps, but I wanted to go with a 2 piece option, like the Avid XX rotor. The question is will any Avid rotor work with Juicy 7's? Will any brand rotor work, like a Hayes or Hope 2 piece? According to Avid they only call out clean sweeps for the juicy 7.
    Thanks for the help.
    Powered by Pulvoron
    Reputation: dirt diggler's Avatar
    Hope 2 pcs works like a charm. Avids with their CPS system can make any aftermarket rotors work.
    One Gear
    Reputation: .40AET's Avatar
    I've run Hayes rotors for 2 years with the J7's. Much better rotor than the stock Avids. As long as they are the same diameter, you should be good.
    Nickel Havr
    Reputation: Eckstream1's Avatar
    You could run larger rotors with the proper adapter...
    Quote Originally Posted by William Blake
    Great things are done when men and mountains meet. This is not done by jostling in the street .
  1. Avid Juicy 5 Vs. Juicy 7 & Rotor size
    By sperlingjf in forum Beginner's Corner
    Last Post: 01-06-2009, 10:37 PM
  2. Replies: 3
    Last Post: 02-25-2007, 07:23 PM
  3. Hayes rotor with Avid Juicy 7
    By x9typesh in forum Brake Time
    Last Post: 07-01-2006, 09:33 PM
  4. Avid juicy 7's rotor in place of Avid Mech rotor?
    By jamisdakar in forum Brake Time
    Last Post: 12-27-2005, 10:54 AM
  5. Bent rotor of avid juicy 5 ?
    By ohvina in forum Brake Time
    Last Post: 12-01-2004, 10:59 AM
