Straightening a hose- Mtbr.com
Results 1 to 6 of 6
    Reputation: Eagle824's Avatar
    What is the best way to get a new disc brakes hose straightened out?? They are so coiled up in the packaging its hard to get them to lay nice and straight. Thanks!
    Tool
    Reputation: Pedalphile's Avatar
    Check Sheldon Brown's site - he may have left us a solution for this.
    If you haven't already, I would just mount the cable to the bike, and tape it in place overnight if the curls are causing problems or just looking messy - the cable may lay flat once you remove the tape. Once the cable is installed, you also might have better luck working the curls out.
    -Pete
    I can barely get my mouth around it.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Usually it needs to be unwound. You can also hang it. And blow dry it a bit.
    Never trust a fart
    Reputation: frdfandc's Avatar
    I just hang mine for a day or 2 from the brake lever. Works fine.
    Thanks guys!
    Reputation: madskatingcow's Avatar
    I just use a hairdryer, to heat the hose a little. Allows you to make all kind of twists or straighten the hose
