Straighline levers on Avid Juicy Carbon- Mtbr.com
Results 1 to 2 of 2
    I seem to have stripped the little bolt that holds in the pin on the juicy carbon lever. When looking at new levers, I ran across the straightlines. I see where they are available for juicy 5 & 7's but am wondering if they will work directly with the carbons? I have a feeling that there is just enough difference between the 5/7's and carbons that frustration will ensue, if I don't check into this first. BTW, I did a search on this and didn't find anything, so any information will be greatly appreciated. Thanks.
    According to CRC, they look like they'll work.
    Our levers are truly an upgrade rather than a replacement lever. A tremendous amount of thought has gone into the design of these CNC'd works of art.
    Here's what we did:
    Suitable for use with Avid Juicy5,7,carbon and ultimate
    Broader faced, reduces tendon fatigue in fingers/wrists
    Optimized length to balance braking power vs. modulation performance.
    Pull has been optimized for maximum comfort and braking control.
    Work perfectly for 1 or 2 finger braking.
    The end wraps 180 degrees around finger and constant radius feels consistent during the full throw of the lever.
    End is relieved to minimize finger pinch
    Bulged end doesn't dig into finger during those last second panic grabs.
    Polished & anodized with an array of brilliant colors.
    Our levers are designed to feel the same cross platform. I.e. Our Hayes levers, look, feel, and pull the same as the Juicy levers
