Stop this freakin squeekin- Mtbr.com
Results 1 to 12 of 12
    www.thetexasoutdoors.com
    Reputation: srwhouston's Avatar
    So I made the mistake of using a buddies oily spray on chain lube. Well I guess it got on my disks, because now they slip and squeek to no end. I have pulled and degreased and brake cleaned the crap out of them. They hold good now, but still squeek upon engaging on the front. Does that crap soak into the pads or what?
    www.TheTexasOutdoors.com
    ^^^ everything outdoors in Texas
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    it soaks in
    you can try to bake them until they stop smoking, sand em down a little and clean the rotors with ISO
    Honestly... ahh I give up
    Quote Originally Posted by highdelll
    it soaks in
    Or fry on medium heat for about 5 minutes.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Yep , about 350 degree's should do it , let cool and sand with 120 grit .
    never heard that before, thanks guys
    ~Disc~Golf~
    Quote Originally Posted by AZ.MTNS
    we've been over this before!
    120 is too coarse 138.2 grit is what's needed
    Quote Originally Posted by jeffscott
    let me guess, in some chain oil
    Quote Originally Posted by srwhouston
    Well yeah, like duhhhhhhhhhh. You don't want the pad to stick to the pan do you?
    Lead by my Lefty............... right down the trail, no brakes.
    AZ
    AZ is offline
    Doh!!................
    Rabid Lana fan
    Whether you choose to bake your brake pads or pan fry them, don't forget to let them cool to room temperature before serving!
    rOCktoberfest 2015 pt I here
    rOCktoberfest 2015 pt II here
    If your time is worth that little you need a new job. Buy a new set???
    Singletracker
    Jun 2005
    Quote Originally Posted by Coop29
    Baking some pads is easier, quicker and cheaper then going to buy new ones.
