SRAM Level TL Brakes Busted Seal?- Mtbr.com
    Jan 2015
    Any help would be appreciated... I was installing a Sram Level TL brake on the fork of a new bike. My understanding was it was prebled. After removing the plastic guard between the pads and installing the front wheel I clamped down on the lever and immediately there was the sound of a sharp loss of air and oil shot out of the middle of the brake body. The piston does not engage and every time I press the lever oil seeps out of the brake body at the same spot it shot out.
    B A N N E D
    Take it back to where you bought it, the brake is faulty.
    Reputation: gmats's Avatar
    Apr 2005
    Yes, take it back. The brake caliper failed.
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Quote Originally Posted by Anbtucson View Post
    Just to be sure....
    These brakes were mounted on the fork and the front wheel and rotor was installed?
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
  1. SRAM Level Brakes thoughts
    By Awesomecat18 in forum Brake Time
    Last Post: 09-01-2017, 09:14 PM
  2. XTR Trail brakes vs SRAM Level Ultimate weights
    By jabrabu in forum Weight Weenies
    Last Post: 06-18-2016, 06:00 PM
  3. SRAM Level brakes vs. Shimano brakes
    By jabrabu in forum Brake Time
    Last Post: 06-09-2016, 09:41 AM
  4. SRAM Level brakes
    By DLd in forum Ibis
    Last Post: 02-29-2016, 04:00 PM
  5. Replies: 11
    Last Post: 01-24-2012, 05:36 AM
