Sram guide RSC lever sticky and slow to return- Mtbr.com
Results 1 to 10 of 10
    Feb 2014
    Hi all, I've got some sram guide rsc brakes that are around 5 months old.
    Been working great, except just the other day I noticed that one of the levers is a bit sticky, harder to pull in, and it's also a bit slow to return back to it's resting position. Just feel tight kinda.
    If you pull the lever further away from the bars, it moves very easy and smoothly. So the lever itself feels good, it's only when it's pushing and pulling on the cylinder?
    I've tried doing a bleed, and also unscrewed the 2x torx screws and removed the lever, tried to clean it a bit and put back together.
    But still the same..
    Any ideas?
    Joel
    Reputation: Steel Calf's Avatar
    Feb 2010
    Quote Originally Posted by Joel Fitzgerald View Post
    Any ideas?
    Joel
    I experienced similar problems with my RSC too. Will talk with the Sram guys next week maybe they know sth
    Feb 2014
    Let me know what you hear. I'm going to talk to the local bike shop tomorrow. Worried they will think I'm complaining about nothing as brakes still work. But feel all wrong.
    Sent from my Nexus 5 using Tapatalk
    Low speed, High Drag
    Reputation: kevhogaz's Avatar
    Any updates on this? My Guide R does the same thing. Works perfectly, but the lever is slow to return.
    I need a cool saying to put here.
    Feb 2014
    I had to send the lever back to SRAM via the local bike shop.. Returned 1x week later, repair sheet mentioned all new internals fitted to lever. Good now
    Well, that sucks. I bought it from Art's, and my girlfriend threw away the box!!
    Feb 2010
    Quote Originally Posted by kevhogaz View Post
    sorry for answering so late. The reason for that sticky lever may be sticky brake piston seals in the caliper. Put some dot on these caliper seals cycle the brake pistons a few times and see if it gets better.
    Feb 2010
    punish her by mounting them on her bike then. Make sure they suck some air in to make things worse
    Thanks, I'll try that, and see if it helps!
    Reputation: emeterio's Avatar
    Where are these seals?, same problem here and cant figure out where to put the dot oil
    No dudes, no temas, no te arrepientas.
  1. XT M785 brake lever slow return
    By jeate in forum Brake Time
    Last Post: 04-12-2015, 02:44 PM
  2. XT lever slow to return
    By wjh in forum Brake Time
    Last Post: 02-12-2015, 06:00 AM
  3. SRAM xo brake lever - sluggish return
    By noonievut in forum Brake Time
    Last Post: 03-16-2014, 03:34 AM
  4. avid brake lever slow return rectified!
    By eric22 in forum Brake Time
    Last Post: 05-10-2013, 10:27 AM
  5. XT slow lever return
    By skywalker268 in forum Brake Time
    Last Post: 02-26-2012, 01:54 PM
Members who have read this thread: 4
