Squeeky Juicy Brakes- Mtbr.com
Results 1 to 17 of 17
    Reputation: jkmacman's Avatar
    Sup MTB Peeps???
    Earlier this summer I got a set of 2nd hand Juicy Brakes on my fs mtb. A few months ago I asked a reputatble lbs (campmor) about squeekiness, and they recommended some rubbing alcohol to be applied to the disks to clean them out. I do this frequently, but more often then not I get the squeek. I have two wheelsets and the juicy rotors are on the better wheelset then I use more frequently.
    thnx!
    Look to where the river ends, or where the river starts...
    2010 RockHopper Comp Disc
    search my friend, you are not alone and rubbing alcohol aint curing anything.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Is it a slight squeak or a loud squeal?
    The pads could be contaminated. Replace the pads. Sand the rotors with 600 grit and tons of water. Bed the pads in.
    the noise can be loud at times
    btw: is changing the pads hard? i change the break pads on my car recently, my wrench is good but he's famous for selling stuff he has laying around. on my last build i had a sweet carbon (giant) bike and he wanted to put 105's on wtf, before that he put an xtr rear dr on my other road bike, kinda cool, but no doubt it's all he had at the time and the 106 crank is old school but still sweet enuf
    Reputation: onegymrat's Avatar
    Try using organic pads. They will not squeak and you'll have better modulation, but you will lose a bit of power.
    Religion = Non-thinking
    Reputation: louisssss's Avatar
    bring them in for warranty, avid covers this howling problem. They will replace ur rotors and pads free of charge and that fixes the howling problem when ur braking.
    RH SL Pro
    Meh.
    Except he bought them second hand, so no warranty.
    in that case changing to diff pads and rotors will likely solve it...
    RH SL Pro
    swapping the stock avid pads with some KoolStops solved the screeching, howling, sound for me on my Juicy 5's (160 mm cleansweep rear rotor, 185mm cleansweep front rotor)
    where can i find those koolstops for my Elixir 4's?
    will they be the same as Elixir R's?
    RH SL Pro
    ha, sram has never asked about it with me... i've had a few second hand items warrantied, no questions asked! Of course i always tell the LBS that i bought them a while back in some little shop in arizona and never installed them until now... works every time.
    but i've also had them do it no questions asked without my lil story
    Quote Originally Posted by Dictatorsaurus
    The way I see it right now, if my bike is too heavy, then I'm too weak!
    Meh.
    Quote Originally Posted by louisssss
    What caliper is the Elixir 4 using? I was under the impression they used Juicy 3 calipers with Elixir levers? Post a picture.
    AlexJK... kind of shady...
    Elixir or Juicy 3 calipers?
    RH SL Pro
    Meh.
    Not an Elixir caliper... or even a Juicy 5/7 caliper... Juicy 3 caliper. You use Juicy pads.
    hahaha, i don't think they really care, they NEVER ask, i just say that for extra insurance, of course i'm careful of how many times i use it at a given shop...
    before i go any farther, wow... that is shady
    at least the LBS is cool
    squeeking sux, no one wants to ride w/a squueker
    You can order them here (6th one from the top)
    http://www.utahmountainbiking.com/sh...brakepads.html
