Results 1 to 8 of 8
    Reputation: Smilerz's Avatar
    Squeaky rear brake
    I have a fairly new Mojo Sl about 2 months old with the SLX kit and the Formula RX, 180mm Front Rotor, 160mm Rear Rotor brakes. Since I got it the brakes the rear one has squeaked and squealed a lot. The tech at the shop said it would go away after a break in period. Well it hasn't and it is really annoying. I am going back to the shop tomorrow to have it checked out. Anyone have similar issues with these brakes. I realize they are not high end but I ride with a lot of people and I do not hear any brake squeals. Could it be my braking technique, I have never had a bike with disk brakes and perhaps there is a way to brake properly?
    Reputation: PeterMarv's Avatar
    Jan 2011
    The "wait it out" thing is what i would suggest. My dad just bought a BMC Trailfox with Deore brakes that squealed and howled for the first month. The noise did go away, but not after a few annoying rides.
    How long do you think is a reasonable time,I have ridden at least 20 rides and the noise is getting worse.
    Reputation: MSU Alum's Avatar
    It should be broken in by now. Maybe the rear brake pad housing is not aligned properly? Or, try cleaning the pads and disc with rubbing alcohol. It shouldn't be squealing anymore.
    I took it into the shop and they sanded the rotor with 100 grit sandpaper so I will give that a try.
    Reputation: Edwards's Avatar
    i had this same problem.sanding it down worked for me.
    mmmaxxis
    If they sand the brake pad and apply rubbing alcohol onto the rotor, there should be no more disc brake squeal. If that did not work, then the brake pads are probably not aligned properly.
    Reputation: interlude27's Avatar
    I'm having the same problem with my front disk brake...Im pretty sure that its broken in...I DID only get it a week ago...but have ridden it every day at least 10+ miles since then. It just started today, and squeaks really loud even when I'm not braking. I think I might have knocked one of the pads loose? I checked and it rubs...not really bad, but it does.
  1. Replies: 0
    Last Post: 04-11-2008, 07:44 PM
  2. 29er squeaky rear disc brake
    By crux in forum 29er Bikes
    Last Post: 06-13-2007, 01:18 PM
  3. Squeaky Disc Brake
    By TheLaxPlayer in forum Brake Time
    Last Post: 08-11-2005, 05:46 PM
  4. Blur with squeaky Hayes rear brake
    By Jesterrider in forum Santa Cruz
    Last Post: 07-13-2004, 11:41 PM
  5. Squeaky disc brake help...
    By mtngoat00 in forum Brake Time
    Last Post: 05-02-2004, 10:33 PM
