Sphere of fluid at tip of bleed screw on Shimano m785 caliper- Mtbr.com
Results 1 to 2 of 2
    Mar 2012
    I recently bled my front brake, and tightened the bleed screw. This morning I noticed a sphere of fluid at the tip of it, even though the screw is completely tight.
    I undid the screw and checked the o ring, and that is fine. The screw hole is perfect (not stripped) and the screw threads are clean. There are no contaminants anywhere, so this is a mystery.
    I would try to tighten the bleed screw more, but I accidentally overtightened the rear caliper bleed screw hole during this most recent brake bleed session.
    Is there any explanation for this sphere of fluid at the top of the bleed screw despite it being tight?
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Take a rag or paper towel and remove any residual fluid from the bleed nipple and see if it re-appears. I've seen this appear as I tighten the bleed nipple, but after clean up, no more appears.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
  1. M775 Caliper compatible with M785 Brake Lever ?
    By Goran_injo in forum Brake Time
    Last Post: 09-24-2013, 05:24 AM
  2. Shimano XT M785 caliper with an XTR M988 lever?
    By Louiepou in forum Brake Time
    Last Post: 08-19-2013, 04:04 AM
  3. Shimano XT M785 caliper with an XTR M988 lever HELP !
    By Louiepou in forum Beginner's Corner
    Last Post: 08-18-2013, 12:34 PM
  4. Shimano XT M785 disc caliper broken
    By rave81 in forum 29er Components
    Last Post: 04-17-2013, 12:51 AM
  5. Shimano XT M785 Caliper Mishap
    By phosphor in forum Brake Time
    Last Post: 08-21-2012, 11:22 AM
