Results 1 to 12 of 12
    So.......what kind of Brakes are on mine?
    http://www.trekbikes.com/us/en/bikes...ries/4500_disc
    is the bike I got?
    What kind of brakes (hydraulic) do I have, or is it also Shimano?
    and is it decent?
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    If you bought it new, that info is in the detail summary you linked.
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    wyrd bi ful rd
    Reputation: chinaman's Avatar
    It is a shimano m445 which is quite respectable being a opposed dual piston design. Take your bike out for a ride for at least 100 miles and then you will know if the brakes are not sufficient ...
    You need to know how your brakes will work for you on a flat road by doing lots of hard braking ... then you do the same on a flat trail ... (make sure you shift your weight over to the back of your bike, over the back wheel, on hard braking) ... that way you know how fast your brake can stop your bike ... and when you are out on the trails if the brakes don't work as well or fade after prolonged use, then you will know it ...
    Reputation: jpeters's Avatar
    Shimano brakes are good but they get better after they are broken in.
    Quote Originally Posted by Malibu412 View Post
    Well I wasn't sure if the Brake Like "calipers" or w/e and the system are the same.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Mercfh View Post
    I have no idea what you just wrote.
    mtbtires.com
    On wuss patrol
    Quote Originally Posted by shiggy View Post
    And I thought it was just me...
    me 2 ???????
    What I meant was, the actual brakes themselves (like the metal part) I didn't know if THAT part was just shimano, or the whole system (IE the Brake Lines/Hydraulic Reservoir/etc..) were shimano as well.
    Dec 1998
    Did you see ANY other brand listed or see anything other than Shimano logos on the parts?
    mtbtires.com
    Yeah those are shimano disks and calipers and levers and cables its all shimano and its all good. They are not the best model but all shimano brakes are good in my opinion. Plus you are using the bike for xc you should not need more.
    Just so you know for future reference, hydraulic disc brakes are a complete system. You can't mix brands between lever and caliper, and they don't sell 'mixed part' bakes. If the brakes are Shimano XT for example, the lever, hose, caliper and rotor are all XT level
  1. What kind of brakes are these?
    By Slimpee in forum Vintage, Retro, Classic
    Last Post: 02-04-2009, 08:51 PM
  2. What Kind of brakes are these?
    By Jake_HT in forum Downhill - Freeride
    Last Post: 07-06-2006, 03:52 PM
  3. TRADE: XC brakes for mine or rotor swap (x-post)
    By FoShizzle in forum Brake Time
    Last Post: 08-25-2005, 07:58 PM
  4. What kind of brakes do I have?
    By Jared in forum Brake Time
    Last Post: 08-13-2004, 09:23 AM
  5. what kind of brakes
    By CESARVEGA in forum Yeti
    Last Post: 07-08-2004, 09:35 AM
