smashed rotor- Mtbr.com
Results 1 to 10 of 10
Thread: smashed rotor
    Reputation: cdirte's Avatar
    smashed rotor
    is there a point that too much bend in a rotor renders it useless? smashed mine against a rock during a crash, and i cant quite work out enough of the wobble to get it to work properly. it seems like there is a ripple in it now, and no amount of tweaking has returned it to true...its not the end of the world...but any help or knowledge on this issue would be appreciated.
    Im no expert, but most here will suggest you just get a new rotor. At least that is what I have learned from many threads here.
    fair enough....kind of thinking the same thing, guess i was just holding out hope that somehow i wouldnt have to drop the coin on a new one. thanks
    +1
    Brakes run with such small tolerances that to accept a small amount of rub would make them pulse as the warped bit ran through the pads too.
    You can try ridding the brakes a bit while going down a really steep hill, then you can take a crescent wrench and true it a bit to the pads. Sometimes heat will make it a lot easier to true
    May 2005
    make a wall clock out of the bent rotor.
    Reputation: Steamer19's Avatar
    Nov 2006
    Also agree. I had the same thing happen and I spent so much time trying to straighten it out but never could get it right. A simple warp seems to be not too bad but once they get a ripple, it's over in my opinion.
    XC Ground Pounder
    Reputation: quietcornerrider's Avatar
    Quote Originally Posted by PB Matrix
    +1
    I concur. Or a huge coaster.
    But if you're hellbent (pun intended), and plan on warping the hell out of more rotors, buy a set of Drumstix
    http://www.bikepartsplace.com/discou...tool-drumstix/
    They make rotor truing quite a bit easier, and baking them a bit helps too (the rotor, not the tool).
    May not be worth the money if you don't plan on truing a LOT of rotors, since most new rotors are less than the tool.
    Well, since they gave us a KHS forum, I guess I have to come up with something else for a sig.
    i now have a new decorative piece of bike art...and a new rotor on my bike.
    XC Ground Pounder
    Congrats! Lets see what old man imagination comes up with for the old rotor!
