SLX brake on DH bike?- Mtbr.com
Results 1 to 6 of 6
    May 2020
    Just bought a used DH bike for a very good deal. All she needs is a front brake. I have the latest SLX's on my hardtail, and I'm wondering if an SLX up front would have enough power. The bike comes with a 203mm shimano rotor in front and there is a saint rear brake (Maybe 2nd gen) on there. Any advice is appreciated.
    Always in the wrong gear
    Reputation: Impetus's Avatar
    Aug 2014
    Need a good brake for the front. I would not put a 2-piston brake up there on a DH bike or even an enduro bike. Id want a proper 4-piston caliper.
    Either buy a matching Saint, or move the Saint up front and shorten the line. SLX could be enough for the rear. Maybe not. Depends on your weight and how hard you charge.
    Shiftin' jumps and huckin' gears
    RAKC
    Reputation: tigris99's Avatar
    Quote Originally Posted by Impetus View Post
    Your about a year out of touch with components.
    Newest version slx are either 2 or 4 piston.
    And a DH trail or endure trail can be alot different depending on where it is. Everyone says at my size I should be riding 4 piston, been riding 2 piston for years and never left wanting more, brakes never an issue.
    Sent from my SM-N975U using Tapatalk
    May 2020
    Tigris is correct, I am referring to the quad piston SLX's. I also only weigh 140lbs.
    Reputation: cookieMonster's Avatar
    How will you be riding this DH bike? (Obviously downhill, but the type of trail really matters). You are light enough that an SLX 4 piston would probably be just fine on park flow trails and cascading steeper trails.
    I ride some trails that are steep AF for a long distance, and the only thing that has worked for me are Saints or Zees with 203mm rotors front and rear. Any lesser brake has overheated, boiled over, and even faded to nothing.
    May 2020
    Ya my trails aren't too steep, mostly I'll be riding mountain creek, thunder mountain, windham, and whiteface. I prefer some good flow trails but I'd like something that can handle some gnarly tech if i feel like it
  1. Replies: 0
    Last Post: 10-14-2013, 10:59 AM
  2. Can I use SLX FD-M660 on SLX FC-M665 crank??
    By bendik.ph in forum Shimano
    Last Post: 09-25-2011, 01:34 AM
  3. Shimano M665 SLX 36/22 crank compatible with SLX 24T 10-spd chainring?
    By eurospek in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-01-2011, 07:04 AM
  4. Difference between Shimano 36 tooth chainring on SLX 660 and SLX 665?
    By Wildeyes in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-02-2011, 02:59 PM
  5. Replies: 0
    Last Post: 01-22-2011, 12:31 PM
Members who have read this thread: 73
