Shimano xt m775 dual control compatible with xt m785 brake calipers?- Mtbr.com
    Mar 2012
    So i'm still using good old dual control xt m775 levers. But i have some problems with my brakes. It takes long to get them rub free and i think they had their best time. So is it maybe possible to use the xt m785 calipers with my dual control levers?
    Thanks alot!
    B A N N E D
    Feb 2012
    Yes they will work but you are not going to gain any performance benefit from switching. If your pistons are sticking, clean and lube them with a few drops of brake oil.
    I have had the dual control levers paired to both m785 and old LX calipers and there is no difference in performance, with the exception of the LX calipers being much more reliable and problem free. You are going to need new hoses, too - the m785 use a hose with a crimped-on banjo (that likes to leak).
    Mar 2012
    Thank you both!
    So the brakes won't be easier to set up with the m785 calipers?
  1. M775 Caliper compatible with M785 Brake Lever ?
    By Goran_injo in forum Brake Time
    Last Post: 09-24-2013, 05:24 AM
  2. What is the latest Shimano XT/XTR Dual Control pods that where Avid BB7 compatible?
    By zanq in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-27-2013, 01:27 PM
  3. compatible disc calipers for shimano m775 levers?
    By gauncher in forum Brake Time
    Last Post: 04-17-2013, 05:44 PM
  4. Replies: 4
    Last Post: 07-26-2012, 02:05 PM
  5. Replies: 1
    Last Post: 08-28-2011, 02:07 AM
