Results 1 to 2 of 2
    May 2005
    shimano v-brake / xt and the loose spring rod
    im not sure what its called, but I will call it the spring rod. Anyways, I am trying to put my v-brakes on today, and Im not sure if something came un-done, but the "spring rod" is real loose and doesnt seem to keep the tension for the calipers. The "spring rods" are loose either way.
    May 2005
    on my old v brakes, the big spring wasnt as weak, so ... I guess the v brakes just have a sloppy spring regardless of how the screw is tentioned, then again i could have a bad lot.
