Which Shimano Rotor?- Mtbr.com
Results 1 to 3 of 3
    Reputation: Slurry's Avatar
    Dec 2008
    So I have Shimano BR-486 Disc brakes. They came with 160mm rotors front and rear. I'm in the process of upgrading the front to an 180mm rotor.
    The original rotor was a Shimano SM-RT61 (160mm), with a ~16.5mm brake track
    I am using the Shimano F180P/P adapter that uses two sets of bolts (AFAIK this is the correct adapter)
    The rotor i purchased was a SM-RT75MA (180mm), but it has, to my disappointment, a ~14.0mm brake track, and the pads hit the rotor arms. I can add a couple spacers under my adapter bracket to remedy this,but I just want to have the right setup.
    The Shimano Techdoc says the M486 needs to run a RT-53M for a 180mm, but this is the C-lock version of the rotor, and I need a 6-bolt. The closest thing to it that I can buy is an SM-RT51M, which both QBP and J&B have. When looking at the picture they provide, it seems that the RT-51 has the same larger brake track as the RT61, but no where have I seen a listed size of the brake track itself.
    So, does anyone have this setup and, if so, can you confirm that the RT-51 works with the 486 brakes?
    My Trance came with 486 brakes and happens to have 180 on the front. The fork is a post mount and it uses has the F180P/P adapter on it and has a SM-RT51M rotor on it. Hope this helps you out.
    Dec 2008
    Quote Originally Posted by EastTNmtnbkr
    Assuming the brake pads hit the rotor fine on your setup, then this is all i needed to hear.
