Shimano R785 Squeel but only at low speed- Mtbr.com
Results 1 to 9 of 9
    I have Shimano R785 brakes. The new DI2 hydros. At low speed, just before stopping, they squeel really bad. All other times they're fine.
    Things I've done:
    Cleaned everything with alcohol and also tried brake cleaner.
    Sanded pads
    Torched pads
    Sanded rotors
    Anti-squeel to back of pads
    Sanded rotors
    New pads
    New rotors of same type (XT RT86 160mm 6-bolt)
    Avid Cleansweep G2 rotors
    I am losing my mind with this.
    Any other suggestions of things to try?
    Reputation: 11053's Avatar
    Is the caliper perfectly centered over the rotor?
    Do the caliper pistons engage the rotor at exactly same time?
    I've also tried different wheels. This is on both the front and rear brakes.
    Calipers are aligned and pistons are engaging equally.
    Reputation: giantdefy's Avatar
    Jun 2010
    I did everything you did, but the only thing that worked was putting a piece of electrical tape to the back of both pads. Super quiet now.
    Electrical tape did not do it.
    MEGALOMANIAC
    Nov 2008
    All disc brakes squeal at one time or another. Just ignore it as long as they stop you when you ask them to.
    life is... "All About Bikes"...
    By low speeds, do you mean like >2mph? I've noticed on 5 different bikes now, that some Shimano brakes just squeal at very low speeds, the second you actually start riding the bike the squeal goes away, though.
    Well, I'd say single digit speeds. And it isn't just a light squeal, it's everyone within the block looks at you squeal.
    But I think I fixed it. Electrical tape + different rotors. Rode to work (only two stops though) and no noise.
    And not fixed completely. Light stops at very low speed are fine. Heavier brake input at very low speeds causes the squeal, much like the scenario COLINx86 described. I'm going to assume that's as good as I can get. I'll try a few different brands of rotors and see if anything works better.
    EDIT
    I tried some old Hayes Mudcutter rotors and they are silent now.
  1. 9 speed/10 speed, Shimano/SRAM, Road/Mountain Compatibility Issues
    By Hundun in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-10-2014, 03:17 PM
  2. Confused about 7 speed Shimano Megadrive cassette, possible to convert to 8 speed?
    By Nick_M2R in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-31-2014, 02:56 PM
  3. Can I use Sram 9 speed quick link gold with shimano 9 speed chain
    By crclawn in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-13-2012, 06:06 AM
  4. Shimano Press Fit 10 speed crank and 9 speed external cup compatibility question
    By wildh in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-20-2011, 11:45 AM
  5. Shimano XTR M980 Shadow 10 Speed Rear Mech and 9-speed system...
    By xr_mtb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-24-2011, 08:08 PM
