Shimano power problem- Mtbr.com
Results 1 to 7 of 7
    mnt bike laws of physics
    Reputation: yogiprophet's Avatar
    My M970 brakes have all of a sudden had a major reduction in power. It is very strange.
    When I use them for the first time in a few days, the power is very low until about 1/2 hour into a ride. Then the power is fine for a while.
    What gives?
    Reputation: mitzikatzi's Avatar
    Air in the lines? Flush and bleed the brakes with new oil for a start.
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    MEGALOMANIAC
    Reputation: Hawgzilla's Avatar
    Nov 2008
    Yup, air in the system. Once the fluid heats up and is circulated around after riding for a little while, it expands and or the air is pushed to a dead spot where it has less of an effect on the system overall.
    How are your pads? Is it time for a new set?
    life is... "All About Bikes"...
    bikeaholic
    Yea, it most likely just needs a fresh bleed. I would also check to see if there are any kinks in your brake lines. Sometimes even small kinks can push the fluid in-between the inner (main) hose and the outside coating which would cause a loss in power.
    air?
    I would have never thought air. It just doesn't feel like when I get air in other brakes I have such as Magura. The levers on my Mags just sink into the bar and then they catch, but the power is still there. I suppose since the design is different, air could have a completely different affect. Also, with the shimano brakes, I can ride the bike an hour or even two later and the power is still there...well after the brakes have cooled down. The lever fell is not at all like the typical air squishy feel. The other mystery is that it happened in both brakes at once. I suppose the only thing I can do really is to change the oil.
    Thank you guys very much for your time and help
    ups and downs
    Look for oil seeping past the piston seals on the calipers.
    Quote Originally Posted by rockyuphill
    I didn't see any.
    I wonder if the Shimano oil could just not work as well after a few years.
